TV volume is not within range. you have to turn it up all the way to be able to hear it and there is static
  • rocko6 Mar 09, 2008
    Volume doesn't work. When turned up all the way can only just hear it after t.v has been on for a while.
  • 31 Answers
Need to know what kind of tv and what kind of signal your are using. cable,satellite antenna.....if cable is there a cable box attached
Posted on Mar 08, 2008
Background noise problem with motorola radius cp200 and also crackling status during transmissions
Bill,
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
Hello, I have an RT 2870 RCA surround sound system. When I turn it on all I hear is static and its not until I crank the volume up to around 25-30 before I can hear the audio. How would I fix this problem?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control (volume pot??) may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 24, 2011 | Audio Players & Recorders
Television sound is static y
This status could be caused by the volume limiter inside the unit thus causing static, thus you will need to have it repaired. The cost of this repair ranges from $50-$90 bucks depending on the actul cost of the part causing the interference,
Thanks and please do be considerate while your are passing threw fixya today to leave postive feedback for those who have helped you today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Emerson EWF2004 20" TV
The volume is all the way up, but its as if the volume is about halfway up. Also, there is static in the background
If you are using a DTV box to receive digital TV signals use it to control the volume. Set it to a mid range level and adjust the TV volume to a satisfactory level. Then use the DTV control to raise or lower the volume as needed.
Oct 29, 2009 | Televison & Video
Static noise and when put on max volume still not
sounds like blown speaker inside set. have you tried an external sound system?
Sep 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Volume problem with static sound
Call a good TV Tech and have him replace the Audio Amplifier IC on the board. This should cure the problem.
Jul 29, 2009 | Televison & Video
Problem with the volume of the T.V
I have a 50in plasma phillips has a volume problem sometimes you don't get sound and I go to another channel sometimes it works and when it doesn't i turn on my surround sound and never has failed me.I talked to a verizon service man and he has the same problem he thinks it is a issue with the cable boxes on the signal coming in that channel.I would suggest hook the TV up to your own speakers it will sound better.
Jan 08, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Static
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
