Question about Kenmore 43042 Front Load Washer
Water leaking on floor after every wash
Hi, I have a Kenmore 43042 front load washer, bought in Sept of 03. It has been a great machine until last week. It now is leaking after every load. Mostly on the right side underneath, but then spreading further under. I suspect it may not be completely level, due to being moved a few times over the last several months, but not sure. Help, please!!!! We have two kids and live on a farm......gotta have a washer, but can't afford a new one. My husband will try to fix it if he can (with your help). Thank you for any help you can offer us. Sincerely, Barbara
    President:
  • Kenmore Master
  • 2,651 Answers
There should be an acess panel that your husband can remove(2 screws on either side of bottom of panel. From there you will get a bettter idea of where leak is coming from. might be as simple as a hole in a drain line. take a look
Posted on Mar 08, 2008
205850 model motor
My kenwood 43042 front load wash machine will not spin out and the motor smell like it burning. I just installed a new motor
Jul 12, 2013 | Kenmore 43042 Front Load Washer
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
Kenmore 70 Series Top Loading Washer Leaks
If this is a Kenmore TOP LOADER, you need to remove the exterior cabinet in order to access the washer interior and sufficiently inspect to determine where your leak may be coming from. This is much easier than it sounds. The following link explains how:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link provided and make sure you inspect all hoses and tub seals as well. This is a very simple repair that you can perform without the assistance of a repairman. The average cost of a pump is about $35.
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid), so I can determine what washer configuration you have. I hope you find this information helpful.
Apr 22, 2010 | Kenmore 22422 Top Load Washer
The front load washer is less than 4 years old and has been leaking from the front door since we purchased it. Rust has appeared in front of the door and now has rust on the side due to leaks. I am afraid...
And so you should be. Anyone who continues to use an appliance around uncontained water is inviting electrocution..
I cant begin to fathom out Why??????????
Oct 20, 2009 | Kenmore 43042 Front Load Washer
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
Water leak on occasion front load washer purchased around 2002/03
You need to remove the kick panel (under the front door). There are two screws at the very bottom of the kick panel, one in each corner.
This will give you visibility to see where the leak is coming from.
On the right hand side is the drain pump. The black hose goes from the pump,out the rear and into your drain pipe. It is secured by a clamp and is one possible source of leak.
If that connection is dry, look underneath the tub where the two parts, front and back of drum, come together. there is an o ring sealing the two sections and this is another source of water leak. (major problem is this is leaking)
Failing this you will just have to trace the source of the leak. You may have to take off the top of the washer to check the water inlet hoses which run on the top of the machine but would still show as a leak under the machine. Good luck.
Jun 11, 2008 | Kenmore 43042 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore Front load Belt problem
can your retighten it ,,w / cresent wrench if not bearing is probably shot check for any leaks
Oct 17, 2007 | Kenmore 43042 Front Load Washer
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Kenmore 43042 Front Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
