Question about Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder
Panasonic DVD Recorder - Digital tuner stopped working
My Panasonic DVD (HDD) recorder has suddenly stopped receiving any digital signals. I have a seperate freeview box running through the same aerial, which works fine, so it's not a lack of signal from the transmitter. When I run the auto-tune facility on the DVD recorder, it now only picks up the analogue signals - it won't pick up any digital signals, neither radio nor TV. Any ideas? Thanks!
  • 7 more comments
  • Anonymous Jun 03, 2008
    I had the same problem! I have the singnal connected to a digital converter box, to the recorder, and then to the tv. the digital channels work ok on the tv from the converter box. However, they do not work on the recorder.
  • Veloclaud Jun 03, 2008
    Thanks for your post, Guest - in fact my machine sorted itself out in a few days and has been working ok since - so I'm sorry I can't offer any advice!
  • Ray L Aug 01, 2008
    Same problem. The digital stations stopped working, I tried to reset the unit twice, scanning for stations using setup each time, and it didn't find any digital stations where it had a whole bunch just a day ago.
  • stanolie Mar 19, 2009
    I have the same problem with DMR-EX85EB, no digital signal,
    analogue signal OK. Have tried all the usual, factory reset Etc
    but still no digital signal.
    Can anyone help with a solution.
    Stan.G
  • Anonymous Apr 20, 2009
    I also have the same problem and am considering sending back to Panasonic!
    Really don't know what to do.
    I have a DMR-EZ48VEB and it has the same problem. On my TV remote i have 4 channels but on my video remote I have 1, 2 and just a few obscure channels.
  • Anonymous May 24, 2009
    I HAVE THIS PROBLEM TOO. EVERYTHING WAS WORKING FINE ONE DAY THEN NO DIGITAL STATIONS. RE DID SET UP CAN'T EVEN FIND THE CHANNELS NOW. TV WORKING PERFECTLY OFF THE SAME AERIAL WITH ALL DIGITAL CHANNELS. WHY IS THIS?
  • Anonymous Mar 21, 2014
    It is a Bush B500DTR DV3 Freeview Digital HDD Recorder. The remote control which is needed to do anything on it has never worked properly and I have struggled with it for a long time it has become more and more impossible to use and I need a replacement
  • Anonymous Mar 26, 2014
    box is puttinchannels subtitles on & off whatever button I press. cant get on to library or tv guide. Also mute keeps coming on.
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
Posted on Jun 03, 2008
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
My Panasonic DVD+VHS recorder has suddenly stopped recieving a signal. Aerial still works from dvd recorder to TV.
No signal from this combo unit can mean either one of 2 things; the program information didn't update correctly while unit was in standby, so some digital channels may be missing or scrambled, or you have selected a HD channel by mistake during use (this series does not have a HD tuner, it is only SD which would also produce the no signal issue).
Going on the first possibility, you can reset the unit back to factory default. To do this, while it is on, press and hold (on the front panel, not the remote) CH UP and CH DOWN buttons together until 'SETUP' appears on the display. Once setup begins, and the unit searches for DVB channels, release the buttons. With the remote, follow the subsequent options afterwards, when prompted. Check other menus, then exit. This should restore your unit to all SD digital channels available.
Assuming the tuner works generally, this reset procedure should help (it works perfectly for Australian models of this series).
Apr 23, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
Dvd with analog tuner work when swithc to all digital signal next
This unit will only work if you have a digital cable connection box. If you get cable service you will have this service if not you will need to buy a digital to analog converter box. This can be purchased at any large electronics store, like Fry's or the Micro Center. You can also purchase them on line. Use you favorite search engine and plug in Television digital to analog converter boxes. The search engine will bring up places to purchase them. I hope this information help you with your problem.
Dec 02, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder Logo
1,521 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
