Dryers Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn the dryer on i hear a noise but seems
When i turn the dryer on i hear a noise but seems likethe drum does not want to move
Anonymous
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Mar 10, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
152
Questions
0
Helped
39543
Points
403
IF IT IS AN OLDER MODEL, THERE ARE IDLE ROLLERS THAT SUPPORT THE DRUM AS IT RUNS AND THE CENTER GETS WORN WITH THE ROLLERS WOBBLING AS THE DRUM TURNS. OR IF DRUM DOESN'T TURN THE BELT MAY BE BROKEN.
Fisher and Paykel Dryer making noises after moving it
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Hello, my maytag neptune dryer is making a loud noise while drying. when i turn it off, and turn the drum, i hear a chaffing noise on the left side. i tried to pry the top off, however it doesnt seem to...
Steven your neptune dryer has bearing problems - thats the chaffing noise you hear on the left side - your drum is running off centre , probably pulled that side by the action of the drive belt . Remove back of machine and check out from there . disconnect all power before and during inspection . you may be able to replace bearings on that dryer if you have the tools to do so .
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Drum seems to be rubbing and making noise when turning
the drum does rub ... generally, there is no front or back to a drum. It rides on the rim on the back and on a smaller rim on the door. I normally find a felt "bearing" at these locations. and sometimes, there are wheels at the back on the bottom. Gravity and the drive belt make it work.
I hope this helps you
a
1helpful
Dryer won't start spining the drum
The belt is the likely culprit, you have to look inside to see if it is the belt
Dryer makes a lot of noise and sometime stops
yes the rollers can wear down and make alot of noise I believe there are 2 on yours.
Drum starts to turn but doesn't theres a rattling noise
Not pay you all to help. After waiting to hear from you for the free advice you advertise I decided to just open it up and look for myself I fixed it without your help.
Thumping while drum is turning
probably is remove console screws and lift console up turn power off first after lifting console remove the 3 screws along back edge slide top forward and off resore power and try ..top may ahve been bent down during move not much clearence between top and drum
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
