Question about GE Spectra JGBP30 Gas Kitchen Range
Temp isnt right
I set my oven to 400 degees and it beeps to let me know that it has pre heated and I can still put my hands on the racks i mean its hot but not hot enough to cook anyhting. Will take an hour to cook a sheet of cookies. Already replaced the thermometer.
  • 943 Answers
Thanks for the question the problem is with the igniter i have had the same problem many times just not getting hot enough i changed the igniter and it was fine thanks the appliance doc
Posted on Sep 16, 2008
Manage my life com sears
I would try to cancel it out.. and restart it..if it wont clear, slide the stove out and unplug it or trip the breaker in the fuse box..retry..
Jul 10, 2014 | Ovens
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Frigidare self cleaning oven 554s034p01
What is the model number? The number you posted is for a dish washer.
Jul 21, 2013 | Kitchen Ranges
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Kenmore Model 278-4298892 Built-in oven won't heat
The oven temp. sensor has gone bad. Replace it and that will solveyour problem. The part # is WB21X5301 and cost is $73.49. Canpurchase at http://www3.sears.com/. You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&. It is inside the oven in the upper right or left hand corner. Shouldbe able to remove from the inside. Two phillips screws and pull it outharness also. Plug new one into harness and put screws back in and youare done.Also, on the image it is # 253.
Apr 10, 2009 | Kenmore Ovens
I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Dec 11, 2008 | Kitchen Ranges
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
125 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
