I just bought an RCA tv ad I am trying to set the date and time which I was able to do;however,it is not letting me change the month from Feb to March. How do I do this?
  • 31 Answers
It should change with the cursorbutton on the remote if seems like it's not working first unplug the tv for 15-20 min. then plug up and try again it may be lockedup or just a strange glitch and needs to be reset. we don't see many problems with programing customer settings
Posted on Mar 08, 2008
How do i change the time or date on my eclipse g2 180 mp3
when changing either date or time
1. set the first one then hold the center button for a few seconds then release. It should move to the next column.
Dec 27, 2012 | Mach Speed Eclipse 180 MP3 Player
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Nov 21, 2010 | 2009 Chevrolet Cobalt
Problem is that the date did not change from 28 Feb to 1 March - it wen 29 Feb. How do you control the date change?
You have clearly set the wrong year when setting the time and date. Try doing a factory reset on the machine, then starting again.
Mar 04, 2010 | Televison & Video
I BOUGHT A CASIO WATCH A178WA-1AV CASUAL CLASSIC .I CANT GET CORRECT DAY SAT BUT MONTH AND DATE ARE OK 2-13. NO INFO IN MANUAL HOW TO ADJUST.
Hey makfloyd2
Sounds like you have set the year incorrectly. Continue as if setting the time as you already have done by holding top left button, then when screen flashes scroll with bottom left button and the watch scrolls in the following order - seconds, hour, mins, YEAR, month, day. Check that year is correct and also check the format of the month and date. In England our format is 10/2/10 which is 10th Feb 2010 (dd/mm/yyy), however some casio watches are in US format mm/dd/yyyy. So check this out too.
Hope this solves your problems
Kind Regards
Jim
Feb 13, 2010 | Watches
Started smoking out of the back
Unfortunately RCA are a cheap and nasty budget end television. If it is out of warranty there is little you can do, apart from having it repaired or buying a new one.
The troubling fact is that it sounds like it may have been about to set on fire. This gives concern that it might be, or should be the subject of a manufacturer recall. So in your case, I would contact RCA once more and ask if your set is the subject of a recall? If they say no, say to them that you are going to contact the Recall Agency, because you think this set may have been about to burst into flames. See how fast they respond :>)
Check the link for agencies in your country.
USA consumer recalls Google Search
Mar 06, 2017 | RCA L42WD22 42 in. LCD Television
I cannot change the date on the Royal Time Master TC 100.
Open the cover. Note the three buttons: MODE, SELECT, and SETTING. To set the date, press MODE. The hour will blink. Press SETTING until the correct hour (a.m. or p.m.) is displayed. Press SELECT to actually set the hour shown.
Then the minutes will blink. Press SETTING until the correct minutes are shown. Press SELECT to set the minutes.
Then the seconds will blink. If you want to set them, press the SETTING button to set the seconds at 00 and press SELECT again.
The Year will blink. Press SETTING untill the right year is shown. Then, press SELECT to set the year.
The Month will blink. Press SETTING until you get the proper month. Then press SELECT to set the month.
Finally, day blinks. Press SETTING until the right day is shown and press SELECT to set the day.
That's it. You've reset your time clock. Good luck.
Feb 11, 2009 | The Times ROYAL TC100 TimeMaster Time...
RCA F32450 TV problem
color ic on the blink.
Jun 16, 2008 | RCA F32450 32" TV
Date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Sep 15, 2007 | Rolex Daytona 116520 Wrist Watch
Televison & Video Logo
Top Televison & Video Experts
