Kodak EASYSHARE 5100 All-In-One Printer
Problem for Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AIO Software Installation Problem
By etihwar on Mar 08, 2008
When installing AIO Software the status bar gets just about to the end and then it comes up "AIO Software encountered a problem and must close", I can't even get to where you plug the usb cable in. I've tried installing the software from the disc and from the web and neither work. I've unistalled the program between installations through add/remove programs and through the Kodak Clear program, doesn't make a difference. Anybody have any idea what's going on?
Comments:
Mar 10, 2008
- I am running XP sp2 Home Edition
Mar 11, 2008
- Thanks for the help, still did not work though. It installed Framework 2.0 fine and then right at the end again it said "AIO Software encountered a problem and must close". I tried both the web an CD installations.
Clarification Request
Posted by SDtester on Mar 10, 2008
What OS are you running XP or Vista? if Vista which one? Home Basic Buisiness, 32bit, 64bit, ect.
Same Problem
Aug 07, 2008
-   I have tried to install this software time after time to end up with an error message at the end of the instalation. Kodak has not seen fit to supply a solution. All I need are the DRIVERS NOT THE AIO software.-   jkahn241
Jul 16, 2008
-   I am having the same install prblem, but am running Vista.
Any sloution to getting the AiO software to load properly?
Help!!! Wife in a tirade over this. She can't scrapbook.
Thanks-   jimmurray68
Best Solution
posted on Apr 25, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Fix a program that will work. We are not getting what we paid for. Same probleum Kodak whats is the probleum.
Solution #2
posted on Mar 11, 2008
Very Helpful)
SDtester
Rank: Wiz
Rating: 87%, 117 votes
Try uninstalling your .net framework then installing the kodak software. it has .net 2.0 on the CD and will reinstall it.
Go to add / remove programs and remove Microsoft .Net Framework 2.0
Then do an install from either the CD or the Web download.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jul 03, 2009
Not Rated)
dba0
Rank: Apprentice
Rating: 0%, 0 votes
I know it's late for an answer to this problem but hopefully it will help someone out there!
I had exactly the same problem but thanks to me knowing someone in Kodak from when I worked there, I was able to finally elicit a solution. In fairness, the problem is really associated with Microsoft (surprise, surprise) and the solution is spelt out in http://support.microsoft.com/kb/968001 in my case under Section B (Windows XP). There are a number of registry entries to check and in my case there was a string value WlNotify.dll missing from DLLName (note that it is a lower-case L between the W and N!). I also had a string entry called OldName ironically, which contained the value WlNotify.dll, I wonder where that came from? Anyway, after a final run of the Kodak Clear Utility and a reboot and running the aio_install.exe from the Kodak web site everything came right.
Regards, dba
Was this helpful?
Yes
No
Solution #4
posted on Sep 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't use the easyshare software, I had the same problem when I first installed my printer. Let windows find the printer and point the found hardware wizard to the disc, it might take a while to find all the different drivers since they're scattered in different folders, but at least you'll be able to print, scan, etc.
Popular Solutions for Kodak EASYSHARE 5100
Questions and Unsolved Problems for Kodak EASYSHARE 5100
Do you recommend Kodak EASYSHARE 5100 All-In-One Printer?
Answer
Answer
the docker only prints half the picture. The other side is blank.
Answer
how do i get my kodak esp printer to print darker its ok on normal paper but when i use glossy paper... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
