Hi There,
Here's a step by step guide that will explain in detail how to remove the top cover on your Hoover. The repair was written for a different problem then one you're experiencing, but you can follow along step by step to see how you can remove the top cover.
If you haven't already purchased the actuator arm, here's a link for you to the part on Amazon
Hoover Windtunnel Self-Propelled Windtunnel Actuator Arm
Here's the repair guide:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat
belt rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover.
Once you have removed the top cover, here's a link to a guide that will show you how to replace the actuator arm itself:
http://vacfactsblog.com/2009/12/how-to-change-actuator-on-hoover-self-propel-vacuum-cleaner-step-by-step/
I hope that this information helped you fix your vacuum cleaner. If you have any follow up questions, or need clarification on something, please feel free to use the comment box here on the Fixya repair page, and I'll be happy to answer any of your questions.
If this was helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated by the Fixya community if an answer was helpful.
Thanks again,
Chris Jones
GoVacuum.com
F6212-900...Thanks so much. I appreciate it!
I got it...it was an obvious screw that I had just overlooked. Got it fixed and it works great! Thank you for your willingness to help anyway!
