Question about Microwave Ovens
GE PROFILE SPACEMAKERXL 1800 JVM1870SF when the microwave is turned on the top inside flickers and pops like it is going to explode?
  • Microwave Ovens Master
  • 9,098 Answers
Sadly, we hear of this over and over. This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 08, 2008
CHANGE THE BULB
Remove the top grill assembly. It is usually held on by 2 screws going down through the cabinet top. You may need to tap the grill to the left slightly to get the tabs to release. Once the grill is off, look near the middle of the top edge of the microwave frame for 1 screw that looks like it goes through a metal lip. It will be right above the inside light bulb area. remove screw and then pull the metal tab towards you. The complete light bulb assembly will slide up and out towards you. Replace bulb and reassemble microwave.
Mar 01, 2015 | General Electric GE Profile SpacemakerR XL...
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
I have a GE SpacemakerXL microwave that stopped working after I heard a loud pop. Everything else works, but it does not heat anything. Help?
From the descriptions it likely the magnetron has failed. If you have a digital multimeter post me a comment and I will give instructions to do a rough test.
Jun 06, 2012 | GE Profile Spacemaker Over-the-Range...
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profile™ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
GE SpacemakerXL JVM1443 stays on when door is closed
That's almost certainly a failed primary interlock (upper door switch) or its mount is bad.
See our file on info on door switch diagnosis and replacement.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
740 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
