Question about Kenmore 24902 Top Load Washer
Washer filled but does not run at all
Our washer was fine this am.  Then I put a load in, the water filled up, and then nothing happened.  There does not seem to be any power going to the washer.  I turned the knob, checked the circuit, checked the plug, etc., but nothing.  I'm trying to figure out if if this is something I can fix (I'm not extremely handy), if it's worth it to call a repair person, or if I need to call it a day with this washer (I'm estimating it's about 10 years old).  Any thoughts you have would be appreciated.  Thanks!
  • Betaman2003 Mar 08, 2008
    Thanks for the post.  I called a repairman who fixed it.  It had to do with a connection issue with wires in the base of the unit.
  • 142 Answers
When the unit completes its filling cycle, a relay will be activated to start the wash cycle. A 10 year old unit probably has dirty/corroded or otherwise malfunctioning relay contacts. This should be repaired by a qualified repairman as high voltages pass through these relays.
Posted on Mar 08, 2008
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
How to repair a new washes etw4400 when it fills with water and nothing else happens
You will have to drain the water first by putting your drain hose into a bucket, out a door, etc, or use a shopvac (take clothes out first). This washer has a broken agitator belt. If it is new, call a repairman as should be under warranty.
Jun 16, 2012 | Estate ETW4400VQ Top Load Washer
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Jul 27, 2010 | General Electric WBVH5200J Front Load...
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Kenmore 24902 Top Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
