SOURCE: RGB-PC input problem?
you need to buy a tv converter .i have a... trust televiewer 1600 and it works fine you do need a s video cable and a mini jack audio cable to plug in where your speakers would normaly go. hope this helps
SOURCE: Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
SOURCE: how to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
SOURCE: Setting up Panasonic SC-HT930 to Cable Box & TV
go to this link to get better support
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/model.SC-HT930
