Question about Kenmore Elite 45986 Front Load Washer
Error code I have a kenmore elite washer that just recently started flashing a code evyer time I run a load. It flashes alternately the H & F. What does it mean? I can't find my manel.
    President:
  • 1,294 Answers
Click on your model number (below FIXYA )on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............ if not click 'thanks for trying', prob wil be back on this site.
Posted on Mar 08, 2008
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Problem with Kenmore Elite 45986 Front Load Washer
machine stops before rinse and spinig. and then H and F flasing
Feb 18, 2009 | Kenmore Elite 45986 Front Load Washer
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore he3t front load washer time flashing stuck
Take the front panel off your washer. Inside the washer attached to the side you should find a manual that will help you with the error codes.
Aug 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
