Question about Dell Latitude D600 Notebook
Dell D600 wont go into bios mode
My dell laptop wont get into bios mode. I press F2 or F8 or F12 on startup at DELL logo. It directly goes to a blank screen. Please help
  • mohd shareef
    mohd shareef May 19, 2008
    MY Dell D600 wint go to bios mode when i press f2 are f12 its hang and show other screen and tell to Esc to restat are wait to power off...pls help me to slove this problem
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
Posted on Feb 27, 2010
    President:
  • 778 Answers
Hello Srinin,
You didn't post that you tried the "Del" key, so I'll mention that to try on Boot. Otherwise you should see on your screen during P.O.S.T the proper key/key combo to enter Setup after the memory check (I believe, if it's even enabled). You may have to note the key/key combo on one boot and then try it on the next boot as you only have a second or two to enter the key/key combo.
I hope this helps you, and Good luck.
Posted on Mar 08, 2008
  • 57 Answers
Try an external keyboard or keep press any key on your keyboard untill it gives you an error
Posted on Mar 07, 2008
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
How do i fine the model of my dell latitude laptop
If it's not on the bottom, you can see the model number in the BIOS. (Usually pressing f8, f12 or Del will get you into the BIOS)
It's also usually listed on the POST screen with the Dell logo.
Jun 30, 2011 | Computers & Internet
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
I have a dell laptop. When I turn it on Windows comes up and it stays on the screen that says windows and has the bar that goes from left to right to tell you it's booting. It never stops doing that. I...
Shut the system down by holding the power button for 5 seconds or more. Turn the system back on, as soon as the blue dell logo goes away tap f8 on the keyboard. This should bring you to a menu from which you can select "safe mode". See if it starts in safe mode. If so, troubleshoot further from there. If not press f12 on the dell logo and choose diagnostics. Run a quick scan, see if any errors are returned for the hard drive.
Feb 24, 2011 | Dell Latitude D600 Notebook
Hi, i just fix laptop dell latitude c600, my problem now is, missing system32 then i want to format it, the first boot on bios is diskette drive, i can't change it to cd drive, pls help... thanks
Press either of F12 or F2 to select the Boot Menu when the computer start with the Dell logo. Select CD/DVD using the arrow keys then Enter. Please comment if the information has been helpful. Thank you and regards.
Aug 24, 2010 | Dell Latitude D600 Notebook
Hi, i am having dell inspiron 1525. when i am switching the power on it starts normally but as soon as dell logo appear (at the bios startup option where we can press F2 or F12 for bios)it gets...
1. You may have a power supply issue. the power adapter is not completely charging the battery.
2. You battery may not be holding a charge and needs replacement.
3. Contact Dell support for a technical support.
Aug 10, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Latitude 600 when you turn it on it fires up,goes through the bios dell page can hit f2 or f12 and can get into there ok.It WILL NOT start in safe mode ,f8 not going to mode or f7.Pulled out...
During the POST, press F2 and look through the BIOS tabs until you find the page that lists the installed drives. Usually this is the 1st or second page.
You should have 2 drives installed. Your HDD and an Optical.
If both show up, then the problem is likely unrelated to the ATA Controller (which is part of the Motherboard).
The Dell Recovery CD can be requested from Dell, or you can enter your service tag number on their site to see if it's available as a download.
Oct 16, 2009 | Dell Latitude D600 Notebook
Trouble booting past the BIOS Screen
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Jan 22, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude D600 won't go past the Dell startup screen
Tap the f7 or f8 key, when you turn it on, it should go into safe mode, Go into start programs, accesories, tools, and restore, select restore, select a date closest to today and let it go through the restore pocess, if it suceeds and starts up, rub a good virus program right away, it sounds like you picked up a virus or trojen, just be patient and it shoul be ok, if it won't go into safe mode, let me know, that will require more work. And before you do anything, unplug, remove the battery for a few minutes and replace, try it and if it still won't run, do the above, thanks ,GYM
Dec 19, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
you can restore the whole system by tuning on the laptop and pressing f10 or f11 before the windows logo comes up
Jul 17, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
3,677 people viewed this question
Alun Cox
