My pc will not load up with windows xp eventually got into the bios page & found the hard drive didnt show up as been identified
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Hello 25keno,
    Did this PC ever boot into Windows with the current hardware configuration?
    Thanks.
    Genius:
  • 1,019 Answers
try changing the 4 pin ( Molex power Connector ) for another if you have a spare inside the case.
And check that the IDE Ribbon Cable is pushed in Correctly.
The other test is to feel the top of the drive, and see if theres any movement. If not the drive maybe dead. or incorrectly configured in the Bios Or Virused.
Mike @ Compurepair.
Posted on Mar 07, 2008
  • 113 Answers
Read this whole post you might want to try the last paragraph first.
Take your hard drive out of your computer. In another system configure that hard drive as a master using the jumpers on the back of the drive the configuration should be on the drive itself although it is sometimes obscured.
Set your drive as a slave, again with the jumpers. Install your hard drive and boot the system up.
If the other system does not boot up or if it boots up and cannot detect your hard drive or your hard drive appears empty it is bad. You have to replace it.
If you are successful in seeing with folders, remove the cmos battery from your system for 30 seconds then reinstall and boot it up. This will place your bios to factory defaults and it may detect it.
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 25, 2012 | Computers & Internet
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Can you give me any tips on how to start up my computer when it's saying operating system not found?
  1. Check the system setup, see if the hard disk drive is seen and identified in the bios. If not, reset defaults and see if it ID's
  2. Reseat the HDD, if #1 doesn't work
  3. If the HDD is seen, and Identified, but the system will not boot, then there may be a HDD problem. Run diags on the HDD< see of you get a failure. If you do, replace the HDD.
  4. If the drive passes diagnostics, then try booting to your Windows CD, press R for Recovery console (If XP, Choose Repair my Computer for Vista/7) run the command CHKDSK /R if XP
If that fails, then try a repair install of Windows, info can be found here:
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Compaq Presario 1692 Notebook
Installed a 250GB WD Scorpio and it shows as a 130GB drive
make sure the laptop will handle a drive bigger than 130 gig. if not make two partitions when you set it up, bios wont see it but usually windows will. also, sometimes ive found that if i delete the partition a few times it eventually reads right. dont know why but have done it that way several times. you can also download a diskmanager program from thier website which makes an overlay if your bios wont support a 250.
Aug 23, 2009 | Western Digital Caviar WD2500BB 250 GB...
Ihave installed wista and want to install xp but it shows no hard drive found
Please go into BIOS and there you will be able to look for an option sata ahci enabled please disable that option and then windows XP will be able to detect your hard drive and then install windows xp on the machine. moreover please install windows XP first and then windows vista, thats what the process says
Jul 12, 2009 | HP Pavilion dv2000t Notebook
T30 wont reformat
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS? To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop. If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Sudden Hard Drive stop
Your hard drive may be intermittenly faulty, any abnormal sounds from a hard drive is not good. I would connect your hard drive to an USB adapter and plug it into a working computer's USB port and do a Disk cleanup and defrag, if possible run disk diagnostic program on the hard drive. If the hard drive proved OK then you may have a faulty IDE controller or faulty IDE cable, check the BIOS battery voltage, may need a new one.
Dec 02, 2008 | VIA (CX-VT6421A) (CX-VT6421A) IDE...
Won't go past the BIOS page
Hard drive may be faulty - try removing the hard drive and reboot. It may take a while searching for the missing hard drive but it should eventually move on and show - operating system not found. If this is the case then either your hard drive is faulty or the windows installation is corrupted.
Mar 14, 2008 | Acer Aspire 1200X Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
