"ENTER FITLINXX ID" has recently appeared on the display when we switch on the treadmill. We need to know how to get rid of this because our facility does not accommodate Fitlinxx. Thank you.
I don't know if this unit was bought as a refurbished or not Fitlinxx is a pin number generate feature individuals training unfortunately I Have look thru all my service material and have not found any reference to your problem. I would call customer service at Star Trac here is their number 1-800-503-1221 Good luck
Testimonial: "awesome-o 4000"
1 )Locate
the reset switch on the underside of the treadmill console. Usually
the button is large enough to trigger with a pencil eraser or Q-tip.
Plug the treadmill plug back into the wall. Use the Q-tip to press
the reset button. It may be necessary to hold the reset button down
for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the
reset button one more time with the Q-tip. "CL21" should
appear on the screen. Press the enter key. The display will change
again and show "CL22." Keep pressing the enter key until
the numbers cycle through to the number "CL26." Press enter
one more time. The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
