Please tell me how to connect HP Compaq 6820S to TV. Notebook has only VGA, TV has S video
    President:
  • 778 Answers
Hello Pabi24,
You can use a VGA to S-Video converter/adapter such as can be found here: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=vga+to+s+video&category0=
This will work as long as your laptop's video out/VGA port is working, but won't get your audio to the TV (audio will still emit from your laptop).
Good luck.
Posted on Mar 07, 2008
6820s motherboard
Replace the faulty key or complete keyboard.
Apr 05, 2014 | HP Compaq 6820s Notebook PC - Intel Core 2...
How to connect laptop to my tv
The only output you have on this laptop is a VGA monitor connection.
See manual.
HP Compaq 6820s Notebook PC QuickSpecs c04151583 pdf
You need a TV with a PC connection to view the video.
You will also have to connect up the speaker sockets t the TV audio in via a cable, that depends on the TV.
Feb 01, 2014 | HP Compaq 6820s Business Notebook
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
Compaq 6820s does not turn on
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. However, if the issue persists, then it is clear that the issue is due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. At this point, if your notebook is covered under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
May 12, 2010 | HP Compaq 6820s Notebook
Laptop Beeps 4 time when not turned on and not in sleep
I don't know for sure but if it's not plugged in it may need to be charged and is telling you its at a low battery life.
Apr 03, 2010 | HP Compaq 6820s Notebook PC
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
Feb 26, 2010 | HP Compaq 6820s Notebook
Replace worn touchpad buttons HP compaq 6820s
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Nov 23, 2009 | HP Compaq 6820s Business Notebook
HP compaq connect TV
I believe that model only has a VGA out. So unless your tv has VGA input you would need to purchase a converter.
Thanks,
Lee
Aug 12, 2009 | HP Smart Buy- HP Compaq 2510p Notebook PC...
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
