Question about JBL PB10 Subwoofer
Thump at the time of shutoff
Recently I had a current spike in my house while using my stereo system that shut off all my components (turntable, preamplifier, amplifier and the two JBL PB10). The spike was about one second long, or so. I turned everything back
on and each component worked fine again. When I turned
all system off, using my surge protector, I heard a quite
loud thump in the left JBL PB10 subwoofer (that also was
turned off from the same surge protector). This thump was
heard for the first time in 2-3 years sicne I'be been using
the pair of the JBL PB10. Now is does the same every time
when I turned the system off. What might be wrong with
that JBL BP10 powered subwoofer? Or, how to eliminate
the thump (turning off manually the JBL before turning off
the other components?). Thank you in advance for any
possible assistance and support in this matter,
Emil - Harford, CT
  • Emil_anghel Mar 08, 2008
    To Renosean:
    Thank you very much for your response and clarifications. The problem here is there was never
    a thump in my left JBL SB10 subwoofer at the shutooff using the same powerstrip command to turn of all components off. I personally don't see
    why shutting off the subwoofer from a power strip
    and not from its own power switch would induce that bothersome thump. I believe that something happened to the output capacitor you're referring to and therefore it needs to be replaced, but I am
    not tottally sure that this will solve the problem. In
    any case, thank you very much again.
    Emil - Hartford, CT
  • 492 Answers
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Posted on Mar 08, 2008
  • Sean Johnson
    Sean Johnson Mar 08, 2008
    It is very possible that it was damaged, but many factors play into a pop, before you may have been using a different brand or protection level of strip. Also nearby wires could be affecting it. Depending on the value of the sub you may find it cheaper to replace the entire sub. Capacitor jobs can run cheap or expensive depending on if the part or board needs to be replaced.
I recently replaced my Intermatic EJ500 with a new unit, I noticed it works perfectly fine for one day then the batteries that control the timer drain completely the following day, what could it be?
Line voltage usually controls the timer functions when properly wired until a power outage occurs; then battery power takes over until utility power is restored. Should utility power be off for an extended period of time, eventually the battery will drain completely
Double check to make sure you wired your wall switch timer properly.
Make sure there are no loose wiring connections.
Even though you purchased a new replacement timer wall switch, it could be a manufacturer's defect.
Has your home electrical system experienced any signal spikes? Electronic components are very sensitive to impulse spikes/surges and can be damaged very easily.
If you are experiencing surges or spikes, perhaps investing in a whole house surge protection system (Intermatic IG series) would be the way to go as well. It'll protect all your electronic devices and appliances through-out the house.
Feb 12, 2017 | Intermatic Hardware & Accessories
I have an compact disc stereo system, disc,radio works. phono not working, why ?
I live in California but I do have a memorex system with the same components. My belt fell off my turntable so it didn't turn. It took a bit of patience but I was able to get the belt back on. The turntable is held down by a clip on the spindle. The belt might have to be replaced if it keeps falling off. It will do that if its been used alot. While the turntable is off, if you move the arm you can see if the turntable motor will turn on too. That would be the only other problem you can have on that unit. The repair cost might be more than what the unit cost. Just be patient and careful and you probably can fix it yourself.
Jul 19, 2014 | Memorex Nostalgia Turntable and Stereo...
Model 253.28432807. Household power went off today for a couple of hours. Restored. Freezer has power but display is illegible. Up arrow does nothing. Down arrow changes display but display is erratic and...
Electronic components are very sensitive to voltage surges, spikes or sags.
Voltage is not delivered at a constant 120 volts. With alternating current, the voltage rises and falls in a predetermined rhythm. The voltage oscillates from 0 to a peak voltage of 169 volts. Most appliances and electronics used in the United States are designed to be powered by this form of generated electricity.
During a power surge, the voltage exceeds the peak voltage of 169 volts.
A spike in voltage can be harmful to appliances and electrical devices in your home. An increase in voltage above an appliance's normal operating voltage can cause an arc of electrical current within the appliance. The heat generated in the arc causes damage to the electronic circuit boards and other electrical components.
(Smaller, repeated power surges may slowly damage your electronic equipment, over time too.)
Voltage sags, a.k.a voltage dips or brownouts, is another form of electrical disturbance that can damage appliances as well.
The bottom line, power surges, spikes, and sags can vary in duration and magnitude; and can damage electrical equipment ranging from stereos to computers to any household appliance that uses chip board circuitry sensitive enough to "blow" due to over or under-energizing it.
Jul 03, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Turntable doesn't play
If the turntable stopped spinning then then the turntable belt maybe broken or has slipped off the drive.
Mar 02, 2013 | Emerson Nr303tt Mini-Stereos
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I recently bought a memorex 2601 M Nostalgia Turntable and the belt is broken. Where can I purchase anotherone.
They use the same belts as anders nicholson, email me and I'll get one off a broken unit. Just to make sure measure the length if you still have it. rogzjaji@yahoo.com
Aug 31, 2010 | Memorex Nostalgia Turntable and Stereo...
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Thump or thud coming from speakers when turntable is tapped
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
Feb 23, 2009 | Technics SL-1200MK5 Turntable
JBL PB10 Subwoofer Logo
427 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
