Jensen VM9510 Car DVD Player Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vm 9311 jensen dvd plater in dash and i have had it 2 yrs worked fine....replaced my battery now wont let me watch dvd says engage e brake?? can you help
brandon day
Level 2:
Scholar:
  • Expert 173 Answers
  • Posted on Mar 24, 2010
brandon day
Expert
Level 2:
Scholar:
Answers
173
Questions
6
Helped
70706
Points
251
543210. enter this code in the am/fm screen. now select brake override
7helpful
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
1helpful
2answers
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
VM 9212
I don't think you can. I have a Jensen multimedia head unit as well (VS 9311 or VM 931) and it isn't capable of playing two different features at the same time.
Jensen VM 9311 iPod Classic
The new ipod will not work with anything other than 2008 alpine products. Apple embedded a chip in the actual cable that tells the ipod that it's ok to pay. What you need is an authentic apple video cable that can only be purchased at the apple store...then hook the inputs up to the video input on the radio.
2answers
You might need the jenson media module,that might have came with it.Mine did and I bought it 2nd hand.and a special ipod cable that hooks from the media module to your ipod.
1helpful
Whats the code sequence?
All you have to do to bypass your brake is insert a DVD into the dvd player. When the blue screen pops up just take your remote and press stop stop 1,2,6,4 that will bring up a manufacturer menu that you wont be able to see. Once you do that use your right joystic and press down then right that will turn the brake override on and also make the brake wire completley useless. then you want to set the region code to 1 and turn the macrovision to off. Once you do that all you have to do is press SYS SETUP on your remote control twice to save the settings. Thats it you are all set you will never have to worry about the brake again and you can watch the movie while driving but be careful if you drive eratic and get pulled over with a movie playing its a big fine. Enjoy!
Jenson 9311
how do i bypass my jensen????
5helpful
3answers
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
