Smartwash 058 washer: after filling with water will just sit beeping very five seconds or so - have to press start again to proceed to first spin then same thing happens on second rinse. Note use cold water wash mostly.
  • pungapunga Mar 08, 2008
    At the first set of beeps it stops after filling - after pressing start button again it goes throught the normal cycle until it fills for the final rinse then beeps again. Pressing the statrt button again sets the pump going and uit does the final spin without doing the rinse. It has been doing this for the last couple of weeks or so. I may be imagining it but the machine seems to take a long while to fill as well. I forgot to mention that the hot and cold lights flash also with the error beeps.
  • 1,512 Answers
Does the machine go straight to the spin cycle after you press the start button?
Posted on Mar 07, 2008
  • Graeme Ross
    Graeme Ross Mar 07, 2008
    It sounds as though the load may be unbalanced. Has it been doing this for some time, or just started doing it.
  • Graeme Ross
    Graeme Ross Mar 08, 2008
    OK, in light of that, it may have a failing cold water valve that is not allowing the machine to fill within time allowed. Changing the valve will sort out the problem. And of course, check that someone has not turned of the cold water supply tap... that would produce the same problems. Good luck, thanks for using FixYa :)
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
Jan 08, 2010 | General Electric WBVH6240HWW Front Load...
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cycle Signal Volume
Try this, with power off press spin for five seconds on and five seconds off until 88 appears in the display. After this either it will start with a c1 or it will flash an error code, write down the code and within five seconds press spin again to advance so auto diagnostics will start, if your display is bad F 2 will pop up quickly. Let me know, SearsTechToo
Oct 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
