Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Plumber fixed the sink, now dishwasher is broken
We have a Maytag Jetclean dishwasher quiet plus. My mother's sink was clogged and it was also leaking underneath every time she tried to use it, so she called a plumber and he fixed it. But right after that the dishwasher stopped working.
When you push any of the buttons like "normal" the little red light comes on above it and the heated dry button but no noise, no anything. When you push the Drain/off button it makes a noise where it sounds like it's trying to work but you can tell there's no water being sucked into the machine.
The machine is installed under a cabinet so I can't pull it out or anything like that. I looked underneath it and it seemed like all tubes and things were connected properly. There is a thingy on the right hand side that looks like it should have water in it but there's nothing in it, I don't know what that is.
I pulled on the mushroom looking things in the dishwasher and nothing is stuck.
When I looked underneath the machine it looked like mice had been living under there in the insulation, could mice have messed up the machine?
I also looked to see if the plumber had shut off the water to the dishwasher and I really couldn't tell. I turned knobs under the sink and nothing happened, is there another knob that could have been turned off?
Please let me know if I need to get another repairman in here because this is just getting ridiculous. Thanks.
  • Katydoench Mar 09, 2008
    Thank you I'll take another look.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like the water is off, too coincedantal to brek after the plumber is there, the hot water under the sink is where the water supply to d/w is. obviously youre hot water at sink is working, there shloud be a sperate on/off valve for the d/w somewhere nearby
Posted on Mar 08, 2008
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
Maytag jetclean quiet plus fills but wont wash or drain.
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
Mar 06, 2015 | Maytag Dishwashers
My mother has cancer so needs me to research her problem with her dishwasher. My mother's sink drain water is emptying into the dishwasher. It has to be manually removed since she does not cook much and...
Problems associated with water from the kitchen sink back filling into the dishwasher are caused by the drain line on the dishwasher not having a high end loop. In simple terms, the dishwasher line is too low and is providing a path for the water to flow in the wrong direction. Reposition the drain line so that it loops just above the sink drain. Then, anchor it to the wall so that it does not move. This will provide and air gap and creates just enough resistance to keep the sink water from entering the dishwasher. I have included a link to a webpage that illustrates what I am referring to:
http://homeimprovementteam.com/standing-water-in-dishwasher
If you have any further questions, please post back and let me know. I hope this helps you.
NOTE: If you are experiencing problems with the sink draining as well, then you may have a plumbing releated issue.
Nov 14, 2010 | Maytag Dishwashers
Clogged dishwasher?
disconnect the drain hose from the disposal or under the sink use a 5 or 6 foot long piece of plastic ice maker hose run it down the dishwasher drain hose till it want go any more also put one cup of bleach in the bottom of the dishwasher and let it set for at least 1 hour then turn the dishwasher on to drain and see if that cleared your clog
Mar 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Jul 26, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher does not drain
The drain runs from the dishwasher into either the side of your garbage disposal, or directly into your sink drain. If it is running to your disposal, pull the hose and make sure that the plug in the disposal (where the hose connects) is knocked out. Some have been known to install them without removing the plug. Either way, pull the hose loose and you can use a compressor to blow through it. If the air comes back through the dishwasher, then you are probably blocked in the main drain.
Jun 22, 2009 | Maytag 24" Tall Tub Portable Dishwasher -...
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Water backing up into kitchen sinks
assuming your dishwasher drains into the trap coming down from the sink, you would need to check the S trap located there.
Oct 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
167 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
