Toshiba laptop display flickering
Hi my display gets this flickering horizontal white lines which gets fine on moving the display slightly but then again develops, started a month ago was fine in between for 15 days started having this problem again.
  • bhatlapuneet Mar 08, 2008
    It does work on external display normal , how do I figure if this is problem with cable or lcd
    Problem Solver:
  • 5 Answers
Its broken then.
Posted on Mar 08, 2008
Dark horizonal lines
Hi! Only at booting, or all the way using the PC?
Mar 05, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Lcd problem, colored lines instead of normal display
more than likely it is the lcd cable if you move the lcd does it flicker if so the cable has gone bad
Dec 13, 2008 | Toshiba Satellite Pro A210-EZ2202X...
Display flickers
Hi, Check all your connections are fitted properly it could be a faulty wire if you can try another wire then do so & see if that solves the problem. The only other thing it could be if you had your machine apart & maybe the video card is not pushed right into the slot look for the small white clip that clips into the rear of your PC inside the machine. If none of this works then I suggest your video card is no longer working properly so you need a new one. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | Computers & Internet
Laptop screen has horizontal white lines running across half the screen
Horizontal lines on bottom third of my Toshiba (Satellite Pro) Laptop with XP windows got fixed by flicking my finger on the laptop screen! Was it a loose connection? I don't know. Change of screen resolution did not help, Rebooting, did not help nor restoring to prior dates. Thank you guys.
Mar 27, 2007 | Dell Inspiron 9100 Notebook
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
