Question about HP LaserJet 4 plus Printer
Printer is printing black line
i have hp laserjet4 printer and since one month when i print document one or two dark line is printing in the paper can u pls give me solution for this
thanks
  • 3 more comments
  • chandukaka Mar 07, 2008
    pls give me reply in my e mail
  • Anonymous Mar 23, 2008
    HP Laserjet 4 has 1 1/2 inch wide variable gray shadow down center of printed page. No other conditions and print quality is otherwise excellent.
    Conducted 1/2 page Self Test and no shadow on page. Printed shadow is now darker after 1/2 page Self Test. New toner cartridge purchased three months ago was not a rebuild and has light green roller.
    Advice please and thank you.
  • NKent Mar 23, 2008
    HP Laserjet 4
    1 1/2 inch wide variable light gray vertical shadow down the center of page only.
    1/2 page Self Test found no toner shadow on page.
    Shadow is darker after Self Test.
    Print quality is excellent with no other problems.
    Toner cartridge is new three months ago, not a rebuild, and has light green roller. Problem with shadow started after one month of use.
  • devabagde Jan 14, 2009
    canon 3600 printer toner one time refilling but after fefilling it not give good performance problem of printer given the print out then one inch dark line printed on the left side of the printer & printing quality not better than before rifiliing toner. how slove this problem? please give me some idea.
    thank you.
  • lionman17 Feb 13, 2009
    My printer prints a solid black line on the page in different positions each time it occurs but it does not occur on every page printed. As my printer is 10 years or more old now i am reluctant to get a new cartridge if this is a hardware or software problem.
    New Friend:
  • 159 Answers
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Posted on Mar 16, 2008
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
I have an HP LaserJet4 and I'm suddenly (as of last evening) getting a 41.3 error code followed by a 13 Paper Jam. I clear the jam, warming up, blank page is ejected, I put the printer back on line,...
41.3 - points to a miss match in the paper tray.
First -
Pull out your paper trays, take the paper out and confirm the guide in the back is set to the correct position. (The little mechanism on the tray which allows you to use different paper types, example letter to A4).
Second -
The other which may have happened it the paper handling was mis-configured on the machine:
- Press the Menu Button on the machine.
- Using the + and - button go to the Printing Menu.
- Select Paper confirm that the paper size is correct for the trays within the machine.
Third -
- Depending on the document you are attempting to print make sure the document type is either adjusted to the type of paper your using or to load the correct paper into the machine. I seen where people send you a legal document and your attempting to print it on letter.
Fourth -
It could be a driver related issue, 98% of the time this is not the case. If all fails above, then attempt this.
Let me know if this helps!
Lastly it could be a driver related issue, however if more than 1 person uses it don't count on it.
Nov 25, 2010 | HP Office Equipment & Supplies
I put in a new toner cartrige in my hp laserjet4 and it does not print very dark, whats the problem.
did you peel off the tape from the cartridge before installing it ?
when you want to print something, don't press the print button, select print review and selkect properties, make sure its not printing DRAFT --select fine
have you tried the print test
Oct 18, 2010 | HP LaserJet 4 plus Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Printer only prints half a page
this is a driver problem, try reinstalling the printer with the laserjet4 driver which is a universal PCL driver, this should solve the problem. If not, there is also a blank HP Laserjet driver
May 10, 2008 | HP LaserJet 5L Printer
Documents print part way then stop
I've had similar problems in the past with my 1100dtn printer...there are several possible causes...it may simply be refusing to continue printing because the blue cartridge is completely out of ink...in spite of the black only setting.
Also, it could be some kind of software conflict, virus program, or spyware overload occuring in your PC...especially if the document you're trying to print is a large file, picture, or contains a lot of graphics. Try a test print from windows with other programs shut down.
Try completely removing the HP printer management software and then reinstall the latest version for your operating system from HP's web site.
A firmware upgrade may help. Firmware files and instructions are available on the HP web site. Mine printer has been running bug-free for about 18 months now...since I did a firmware upgrade. Firmware updates are complex...hopefully you'll find a simpler solution....but it may be needed, especially if your printer is more than a couple of years old.
Jan 18, 2008 | HP Business Inkjet 1100dtn Printer
HP LaserJet 4 plus Printer Logo
358 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
