Question about JVC AV-56WP30 56" Rear Projection Television
Convergence not alighning tv screen
Tv screen is not alighned and the remote wont alighn it can i manually alighn it convergence wont alighn in upper left corner
    President:
  • JVC Master
  • 1,779 Answers
No you cannot! There is a switch on the convergence pnl for complete convergence. You can make things 10 times worse if you don't know what your doing.
Posted on Mar 07, 2008
  • mlowe260
    mlowe260 Nov 03, 2012
    I did make things worse on mine. Now I can't get to the setting that I messed with trying to line things out.
Steering heavy and wont go straight
If i READ THIS RIGHT! yOU MAY NEED AN ALIGHNMENT, or front end parts are worn. Usually when vehicle pulls left or right that means vehicle is out of alighnment. or bad tires,Any garage that does alighnment, can fix it or tell you whats wrong. God-Bless!
Nov 05, 2015 | Cars & Trucks
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
My phones screen isnt alighned but when i try to alighn it it wont hit the right spot
use a pointer like you would for a nintendo ds to be more accurate
Sep 05, 2009 | Cell Phones
My picture is wavy, I have a mitubishi big screen model # vs-60607
sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
May 17, 2009 | Mitsubishi VS-60607 TV
Can I repair this problem myself?
You could do it but you would need the service manual to be able to do the tube and lens alighnment. You have to align the tube and lens before you can adjust convergence, and if you dont alighn properly you will kill your convergence ICs trying to compensate. If you would like me to post a link where you can get the manual let me know.
Mar 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
This tv has been a nightmare, its been down 3 times in 4 years.
The convergence board, AA95-01799G is available from http://www.samsungparts.com for about 122 bucks + shipping. You also may need to get the service manual so you can do the convergence alighnments with this set when you replace the board. You will also need the manual to perform the perfect focus alighnment on this set if you have that feature. Good Luck
Mar 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Blue curves up on the ends and red down
Your going to need to hook up a cross hatch generator to adjust the internal convergence alighnments. Anytime, a tube is replaced, there is alot of alighnment involved with the convergence, and it cannot be alighned from the customers convergence controls. I suggest first you get a service manual, and follow the alighnment to the letter for the convergence. If you do not have a cross hatch generator, then your going to need a test disc(DVD) that has a cross hatch on it. If you do not have access to those two things(cross hatch generator or the test disc) you will need to call out a tech to do this alighnment to the set. They (service tech) don't tell you when you get an estimate for a picture tube that there is some alighnment involved that reguires special test equipment. Thats why they charge what they do. I wish I had better news for you, but without proper test equipment, this is going to be a tough battle. Good Luck Please do not forget to rate this thread.
Dec 12, 2006 | RCA D52W19 52" Rear Projection Television
Picture got shadow
First thing to do is go to http://www.servicemanuals.net and get the service manual, as if you dont adjust these things in the proper order, it will never alighn or it will take you hours on end, because most of the time, when you move one thing, it affects the other alighnment, so if you do it off the cuff your having to do one, go back touch up another and may need to redo the same alighnment a hunderd times!~! See my point? Now if one section is not responding to the ajustment, or all of a suddenly the adjustments went out, and you try to adjust them, STOP! The alighnments may drift a little over the sets lifetime, but never will they go out drastacly, unless the convergence IC's go bad. They are the black rectangle IC's that start with STK and are mounted onto stand up metal heat sinks. If your not a tech or know the safty issues with a TV set, please call out a trained service person to assist you with this repair.
Sep 12, 2006 | Sony KP-65WS500 65" Rear Projection...
Distorted view at upper 20% of screen horizontally
Wow for the convergence to shift you must have really moved it. First try the manual convergence on the set. if that dosent help then your gonna need a pro to come in and adjust it for you as it takes special equipment and the know how to do this kind of alighnment as its not a consumer alighnment sorry couldnt assist more. Good Luck
Jun 11, 2006 | Hitachi 43UWX10B 43" Rear Projection...
CONVERGENCE PROBLEM
Yes sir anytime you move a projection set ,theres a chance that the convergence could go out of alighnment as it dosent take much. First off your gonna need a cross hatch generator and a service manual and a good kno how on convergence alighnment as when you adjust some controls you need to counter it withanother completely differant alighnment control> so in some cases to get a section or a linearity correction your gonna spend some time. I myself remeber one set I spend 5 hours on after a customer tryed to adjust the confergence them selfs. Not only did it cost a bundle to realighn the gentleman need to go to the hospital as i results of touching a spot on the chassis that he shouldnt have and gave him a shock that threw him across the room. My advice, unless you have convergence experience is to invest in a service person to come out to your home and adjust it for you. I would try first an authorized repair center as they should have all the tools and secrits to the convergence in that set. And Please without electronic experience, even an unplugged set can harm ya. Good luck Try the # and the link 800) 252-5722 or proinfo@jvc.com
Jun 04, 2006 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
76 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
