Black Screen of Death
What do you think of downloading these "repairs" from Philips? Do they fix this problem: screen goes black with no sound for about 7 seconds. My out of warranty Philips 32" LCD Flat Screen has a USB connection on the side. Should I try giving cyberspace a shot at it?
I have the same problem. I've just upgraded the software on the TV and am hoping that fixes the problem. Seems to only happen when I first turn on the tv for the day. Once its up it seems to be fine. (power cycling a few times to get it to stay though)
  • archermarc Jan 19, 2009
    I have a similar problem with my PHilips LCD flatscreen. I am watching Tivo or a DVD and it goes black for about 7 seconds. If you know of a solution please tell me. I found a few videos on youtube about it and i am still searching.
    archermarc@optonline.net
Philips flat screen tv
Board for the screen has a bad component or a bad solder joint. It will need to go to a repair shop. It may be cheaper to replace the tv.
Jul 04, 2016 | Philips 47PFL7403D 47 in. LCD TV
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
Black screen of death and keyobard not working
sounds like it's more than just the keyboard. but try using a different one.
Apr 03, 2010 | Computers & Internet
I get sound, can change the channels, etc, but my Polaroid television screen has no picture whatsoever; it's just a black screen.
lubbarlubab, Looks like you will need to get a power supply repaired/replaced in your unit. Before you call out the service guy, you should spend 30-40minutes at YOUTUBE and view some "LCD-TV repair" videos and also videos of "LCD monitor repair" and LEARN what are the most common components that are causing this plague of "BLACK SCREEN of DEATH" to disrupt your life. If the "cold-cathode-fluorescent-lamps" fail to light-up due to a failure of a single or multiple $2 parts on a power supply board you have a black screen!! This problem is also very common to LCD computer monitors. Try to view a vid by someone called "cal22583" who did his own repair to a Philips 42" or 50" unit. If this was of some help please rate on fixya.
Bye for now. 12fixlouie
Nov 08, 2009 | Zenith L13V36 13" Flat Panel LCD Monitor
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 32PF7320A black screen
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Jan 14, 2007 | Philips 32PF7320A 32 in. LCD Television
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
