Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
Diagnosing the problem with my bissell quicksteamer plus upright
I was shampooing yesterday when i noticed smoke coming from the base of our bissell quicksteamer upright and so i immediately pulled the plug. i then proceeded to clean out all of the filters which were a little dirty but not enough to cause my machine to start smoking so being cautious I examined it carefully that it when i discovered about an inch of copper wiring cable exposed with no insulation covering it. also i was putting quite a bit of pressure on the machine to vacuum up the water because we have the over priced overrated berber of course. can you please help me troubleshoot the problem because i really love my little bissell its been the most reliable die hard of a shampooer i have had! thanks
    President:
  • 1,673 Answers
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Posted on Mar 13, 2008
Bissell quicksteamer 1950 motor
take bottom apart see if belt broke if bad check motor shaft see if it spins
Jul 31, 2017 | Bissell 1960-3 QuickSteamer Plus Upright...
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
May 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell quick wash no solution coming out
I have exactly the same problem. We have flushed the pipes through put descaler in the area feeding the water solution from the tank and no luck. If anyone can help I'd be very interested.
Jun 02, 2008 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
308 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
