Question about Tomtom GO 700 GPS Receiver
Gas station gong thingy
I purchased a refurbished tomtom 700 for my daughter. whenever she drives by certain gas stations (not all though) or where one used to be it makes this gong sound and a gas pump comes up at the upper left side of the tomtom.. i want to disable this gong as it is annoying.. what do i have to do..
  • 515 Answers
Tap screen, Change Prefs, Right Arrow, Manage Pois, Warn when near POI.
Find the gas station warning, tap it, and confirm removal of warning.
Posted on Apr 10, 2008
I put it 30 dollars of unleaded91 that was given to me from my mum an heard it was mixed with a bit of diesel gas put it into my 2005 Mazda premacy went down the road and the car started shaking an started...
The gas/diesel was in a can from your Mum or you bought the gas/diesel at a gas station ?
The station needs to be responsible if you bought a gas/diesel mix from them.
You will have to have it towed to a mechanic. The lines and tank will have to be emptied of diesel and flushed out. The plugs will need to be changed and it could have ruined your catalytic convertor.
My daughter did a similar thing to her car.
Bad news - it can be a very expensive fix if the cat. convertor is ruined.
Oct 13, 2017 | Mazda Cars & Trucks
Deleted TomTom 720 fuel station icons
Try this guide it should do the trick:
http://www.tomtom.com/support/solution.php?GID=1&PID=1682&SID=0&CID=217-219&Language=1&query=gas+stations&FID=7277
If that doesn't work, just try downloading all the maps and installing them from scratch.
Jul 27, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
I have a 2006 toyota sienna. Awd. Can I just add air to my tires? Or do I need to take it to a tire shop?
Yes, u definitely can add air to ur tires at any Walmart gas station, 7-11 gas station. And mor gas stations should have the air pump. If u don't know how to though, try to pump the tires so they don't look anything like flat. If u can't tell any difference between flat, and full, there's an image below. Whenever u press the throttle( the thing at the lady's pointing finger), it pumps the air. Some gas stations might have free air pumps, but almost all of them u gotta pay like a dollar or something. When pumping air, I wouldn't go more than 4 on a car like that. How to tell if u have 4 units( I'm not sure what the official name of those units is) or less, is when u let go of the throttle( and press the long end to the valve on the tire with ur other hand) there's gonna pop out a small thing out of the short end. It's gonna have numbers from 1 and up. U want ur number to be at 3, maybe 3.5, but 4 is the max I would go on a car like that. If it still doesn't make sense on how to use it, I think the gas station staff should have no problem showing u how to use it
Jun 03, 2015 | Toyota Cars & Trucks
WHAT CAUSES CAR TO SHUT DOWN WHILE DRIVING?
Fuel not flowing to the engine. I had a Cutlass (for a week) that would shut down for no apparent reason. After being towed 4x, I told the garage to drop the gas tank and flush it out, since I thought it might be bad gas that the previous owner could have purchased. When I returned, they showed me a handful of small tinfoil balls that were floating in the tank. Whenever I accelerated, the tinfoil balls were sucked into the screen that protected the gas line from foreign objects being sucked into the engine. I knew it was fuel related but, I had to convince the mechanics. I'm sure you don't have tinfoil in your gas but, you may have a clogged fuel filter if you bought gas when the tanks at the gas station were almost empty. I'm betting your problem is fuel related, in some way. Find a mechanic you can trust. Good luck, John!
Jul 30, 2014 | 2003 Dodge Neon
Fueling causes gas to back-up
Turn the handle 1 way or the other to follow the path of the fill spout as it is at an extreme angle beyond the filler nozzle portion.
Apr 18, 2010 | 2007 Ferrari F430 Spider
Does my 2004 mitsubishi require premium gas or can it use regular
alot of manufactures say to use premium . its not etched in stone though try regular gas if the car runs badly then go back to premium also i would suggest to use stations like exxon/texaco/amocobp these stations add an extra additive to there gasoline that discount stations may not use.
Oct 03, 2009 | 2004 Mitsubishi Endeavor
2001 Nissan Sentra "check engine soon" light comes on after gas fill up, goes out when tank is about half empty. It is not the gas cap.
Do you use only one gas station? Try another station / brand, it could be that the gas supplied to your station is off. I had a similar problem with my old Land Rover, then we found out that there was some illuminating paraffin in the gas. It didn't have a light to show a problem, but just didn't have power everytime I used a certain gas station. The dealer is now under investigation for diluting his gas to make some easy bucks.
Jun 06, 2009 | 2004 Nissan Sentra
Car stalls and is hard to start
Did anyone ck the coolant temp sensor? Air intake temp sensor, MAF sensor etc.
Jul 02, 2017 | 1997 Saturn SC
Your best bet is to reinstall the maps, from scratch. This will ensure that all the maps are included.
This guide should help you out:
http://www.tomtom.com/support/solution.php?GID=1&PID=1682&CID=224-225&Language=1
Tomtom GO 700 GPS Receiver Logo
365 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
