Question about GE (PSS26MSRSS) Side by Side Refrigerator
Door handle loose on Model GSS25WGTA
The bolt is loose on the bottom of the refrig handle. How do you get to the bolt to tighten it???
Ken
  • kenneyg Mar 07, 2008
    Thank you. Does the gasket have to come off around the door first?
    Ken
  • Anonymous Mar 25, 2014
    Loose door handle
  • 46 Answers
There is a cover that runs up and down the door. This cover is removed simply by using a thin screw driver and peeling it off. You will find the Bolts under this cover. BE CAREFUL not to over tighten the bolts..
Good Luck
Posted on Mar 07, 2008
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
How do I reattach handle on freezer door pull that has come unscrewed on French Samsung refrig
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
How to tighten a door handle on a frididaire refrig model #FFHS2622Mw0
The door handle screws are located beneath the door gaskets, simply pull the gaskets loose from the frame and tighten screws then reattach the gaskets.
Apr 18, 2014 | Refrigerators
Have an Amana Side by side refrig/freezer (model ACD2234HRS) that has a loose refrig door handle. How do you get access to tighten the door handle screws?
i believe there are plastic coverings that just pop off. they are located at the hinge,you will need to fully open the doors to get to them.
Sep 20, 2009 | Freezers
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Mar 25, 2008 | LG LRFC22750ST French Door 22.4 Cu. Ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
555 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
