Question about Linksys Wireless-G Broadband Router
Setting up wireless router
I have a network router in place but not wireless, should I remove that router first and then set up the wireless router? I want the laptop wireless and a desk top wired.
If you plan on only using the wireless router once it's set up, you may as well get rid of the wired one right now. You can easily set up the wireless router while the wired is still running (plug your computer directly into the wireless router), but you don't need it. If you have a lot of settings you need to move over (port forwarding, QoS rules, etc.), open those configuration pages of your wired router in new browser windows so when you turn it off, you can see all your settings and copy them to your wireless router.
Posted on Mar 07, 2008
I want to use router as wireless extender
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers. http://www.fixya.com/support/r8279884-setting_router_as_repeater
Nov 05, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
Can i use my old usr 5461 wireless max g as a repeater?
SETTING A ROUTER AS A REPEATER1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URLconfiguration's IP address, This is usually something similar to 192.168.0.13. Enter the configuration user name and password. Therouter will display the various router settings.4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on thenetwork, or any other network devices. If the main router on the network is setto 192.168.1.1 then the repeater router should use a higher number (ie. 10),such as 192.168.1.10 or higher, depending on how many devices are on yournetwork.5. Disable the repeater router's DHCP server. This settingshould be on the same page as the IP address, (this may be different dependingon the make of the router). When the main router is operating normally, thisserver assigns an IP address to every device that is connected to your network.Because this router is used as a repeater, the main router on your network willstill issue the IP addresses.6. Also turn off the DNS server, if it is activated. Thisfunction will be taken over by the main router.7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model ofyour router.8. Remove all in the "Port Forwarding" section. Some routersmay refer to this as "Applications and Gaming," and it allows less-restrictedaccess to the internet.9. Set the operating mode switch to "Gateway" or "Switch" ifapplicable. Also, if the repeater router is a wireless router then disable thewireless access or set it to access point only.10. Save the settings for each page, and reboot the router.When the router boots up, the changes will allow it to act as a simplerepeater. 11. Now, place the repeater router in a newlocation and connect both routers with a Ethernet cable in each
Jul 18, 2012 | U.S. Robotics USRobotics USR5461 Wireless...
Im having a problem with my wireless network
Setting up a wireless network can be a bit tricky at times, but if you follow this step by step guide for Linksys routers, you will have your wireless network up and secure in no time.
It will walk you through resetting the wireless router and quickly setting up a securing your network.
Click here:
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Feb 18, 2011 | Linksys Wireless-G WRT54G Router
I bought an Amazon "Kindle" Wi-Fi reading device
I do not recommend that you use WEP for security as this is no longer a secure method for wireless network.
Click here:
Magoo
Running the wizard from the install CD does not find the router and I know the router.modem cables are connected properly... whats next...
It seems you're setting up a wireless network thru your router. The basic steps in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. As of the moment, we need to use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows.
Click the link below for proper cable connections in setting up your wireless network. This also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Feb 12, 2011 | Linksys E3000 Wireless Router
I have a wired network in my house. An aerial on my roof picks up a wireless signal from a transmitter/receiver unit in the village. I can also pick up a wireless signal from the same aerial. I want to...
You can, in most cases, connect a Wireless router to your POS and let your provider know the MAC address of the device and then go from there for setting up your network. If you don't wish to replace your current router you can connect the wireless router to the current LAN router and establish a wireless network from there. Make sure you set up WEP or WPA security on your Wireless network to keep other people from hacking or using it without your knowledge. This is normally the only requirement Service Providers place users establishing a wireless network.
Oct 12, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Router not connected
First You will need to remove the network from the preferred network list.
Then check the wireless settings on the router. Is there any computer connected to the router ?If ot then you will need to connect the computer to the router . open the set up page f the router. check the security settings on the router,
The try to conect , it will connect.
Click here for more information about how to conect to the wireless network
Jan 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wii wifi connection
Try to uncheck UPnP Enable on your router located on advaced network setting. or try reconfiguring your wireless network settings.
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Microsoft Wireless-G Base Station MN- 700
Just remove the router and reinstall it. it will ask you for new Base name Etc and new wirless network name with new security key codes.
Aug 20, 2008 | Microsoft Broadband Networking MN-700...
Hi there!
1. What brand and model are your modem and two routers?
2. Who's the interent provider?
It is recommended to use one router to avoid double NAT.
May 04, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
