Kenmore 57029 Side by Side Refrigerator Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore not get cold both sides
My kenmore not geting cold both sides
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262438
Points
1837
You fan can't circulate because of failure or frost buildup. If its a stuch fan, a little WD-$) and some pliers can free it up. If its frost buildup try this.
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigeratorsmy kenmore not get cold both sides - 2_bing.gif. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Not geting cold back of frezzer isiceing up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
My fride just stopped geting cold altogether it was made 08/01 is that old for a fridge? Im going to umplug it and leave the doors open for 24 hrs and then clean the coils? Can i replace the froen myself?...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Just brougt had it staningup slinted a litte bit geting off truck wife cleaned it up plug it in comppessor kicking in not geting cold in side
After transportation or tilting one should not plug till after aprox 2 days to allow compressor oil to setle down. Switch off now and let setle for 3 days if does dot work you may have to change the copressor and vacuate the system.
My refrigerator or freezer is not geting that cold.
unplug unit and let sit overnight evap coil is froze up
1helpful
Quit geting cold, started Sunday, things are completely defrosting now. I tried to unplug and restart. The fan seems to come on but the compressor does not. Can't find the defroster timer to see if maybe...
Sounde like the overload is bad on the compressor . Pull the refrig out and remove the lower panel . Attached to the side of the compressor , is the overload/relay . If the compressor is not running , replace this part . Only 2 or 3 wires connected to it . Take your model number with you when getting the part , as you didn't list it here , or a part number could have been given .
2answers
Kenmore side by side ice maker is not geting water. water is on and if I temp change electrical connectors on the silinoid and work the water arm on the door I can get water to the ice tray. What is wrong...
You have a bad water valve . Both solenoids work independently of each other . 1 for the water dispensor and one for the icemaker .The icemaker when 5 degrees and harvests , tells the valve to give it water (electronically) .
1helpful
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
2helpful
2answers
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
