Question about Kitchen Ranges
What is this part called
For GAS Range, what is the part called that underneath the burner that connects the burner to the main gas line? There are 2 long ones for the back burner and 2 short ones for the front.
  • 3 Answers
Its called a venturi.
Posted on Mar 12, 2008
My range master 90gas oven lights but the flame stays small and can not be turned up
gas present no pressure increase
repair will need a qualified gas fitter
has gas thermostats to each burner
and stove sections ..might be one of those
if all burners are affected
the gas regulator main line connection to stove
located at the back into the stove plumbing
Oct 31, 2016 | Kitchen Ranges
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
Stove burners don't ignite ,the regulator isn't letting the gas go to the range kenmore gas stove model 665 75022101
First, check to make sure gas is actually getting to the range and hasn't been stopped by a clog or simply shut off accidentally. Next, make sure the120v AC is present. If you verify that gas *is* reaching the range and there is 120 volts getting to the range, then the main gas valve is next in line(where the gas line connects). The part numbers for the main valves in the range are:
8523378, gas shut-off
8054079, gas valve
I hope this helps you!
Sep 15, 2015 | Kenmore Kitchen Ranges
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
Hi: I just installed Frigidaire gas range and have a couple questions. 1. 2 surface burners each have flame too high on only half the burner. it shoots up pretty high. How can I adjust this? 2....
Hi. There is an adjustment screw on each burner. Just make tiny adjustments until you are happy with it. Regarding the gas hiss, yes that is normal.
3 thumbs up please. Thanks, Joe
Oct 15, 2010 | Kitchen Ranges
I have a whirlpool gas range , it must be the cheapest one as it has no electrical connections,and I have no manual ,how do I light the pilot lite ????
There are actually two pilot lights to light, (maybe three) Under the top there would be the old style flash back tubes leading from two burners to a pilot. This small flame stays lit while the gas is on. When you turn a burner on some gas flows back through the tube and flashes or lilghts the burner.
When you turn the gas on there is always gas through the pilots, unless shut off with the little set screws if you follow the lines. From the factory these are on and open. Small set screws also adjust pilot flame size.
THe other pilot for the oven is down by the main burner. There is a small cap tube from the gas valve to a holder just under the burner. This is where it is lit..........
There is another line to the thermostat when you lturn it on that opens more gas to increase the pilot to a biggger flame to open the gas valve burner assembly.
.Also ranges usually come set for natural gas, and you have to do spud adjustments, regulator, air flow only if you want to change to lp......
Put a new flex line on, and be careful with gas...........
Jan 04, 2010 | Whirlpool GS460 Gas Kitchen Range
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
I have an electric gas stove with 4 burners and oven. 2 front burner is leak and I need to change it so I am looking for those 2 parts.
local hard ware store should supplie gas stove fittings but make sure main gas supplie is turned off before working on seek an call a pro do not atempt to do it your self unless u have experience.
May 05, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
