Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
We have the bissell quicksteamer and as I was shampooing I began to notice something burning so I unplugged our machine immediately; then my mom and I started cleaning all the filters assuming that could be the source of our problem and yes it was a little dirty but I suspected that it would take more thant that to cause our machine to somke soI turned it upside down and noticed there is a cable of copper threads that appear to have some type of rubber or plastic insulation tubing around it but must have overheated and started to melt. There is about an inch of copper threading exposed as far as I can see but it has not unraveled of course I have not opened it up yet I wanted to get your opinion and advice first. thanks!
    President:
  • 1,673 Answers
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Posted on Mar 13, 2008
My bissell quicksteamer makes a high pitch squeal
Something is caught in your beater bar , causing preasure on another part of machine. This contact is the cause of the noise. GOOD LUCK FRIEND.
Sep 16, 2014 | Vacuums
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
Need instruction book for bissell model 1770
Information on your Bissell QuickSteamer 1770 can be found here:
http://canada.bissell.com/Products/p/1770+quicksteamer/Product.aspx
The User Guide for the 1770 /1970 Series is here:
Apr 13, 2011 | Vacuums
I have a Bissell Power Lifter Shampoo Machine but no instructions
I have a bissell power lifter shampoo machine and no instructions.
Oct 01, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissel Quicksteamer leaking
Hi there SmartAlec from NelsonVacuums.com.au here. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Motor problem
I had to throw the machine away before it burned my house down. There is no way to fix it; had to replace it.
May 22, 2008 | Bissell 1770 Quicksteamer II Upright...
Diagnosing the problem with my bissell quicksteamer plus upright
Mar 07, 2008 | Bissell 1960-3 QuickSteamer Plus Upright...
Quicksteamer
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Jun 13, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
188 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
