Question about HP Pavilion zd8000 Notebook
Display Problem My display will start flickering on right side and will totally blank out with different colors and them come back. When i change resolution it will clear up and may operate normally for 10-20 minutes and then start flickering again. i go in and adjust again and it clears up and cycle starts all over again. I just changed system board as ATI Mobility card is on board. This took out the checker board pattern on top half of screen but flickering cycle is still there. Any advice?
  • 1 more comment
  • JCiwjS Mar 08, 2008
    Hi, Mike
    Source for parts and manual to repair?
    Thanks Mike
    I paid for chat with eagle338. you should get part of fee!
    I lost chat session with him when i went to find new driver download and really didn't get much help. It sounds like you have personally handled this problem before. Thanks.
    Found several inverters on ebay. I changed system board successfully, is changing inverter a big deal?
    Genius:
  • 1,019 Answers
Inverters On The way Out.
Try gently Pinching the screen at the top and bottom of where its Faulty ( On the Plastic casing ) Not the actual LCD.
Mike @ Compurepair.
Posted on Mar 07, 2008
  • 1 more comment
  • Mike Waldron Mar 08, 2008
    Hi Buddy,
    Found this repair manual:-
    http://computerdoc.homestead.com/DRSILap...
    They Charge $9.99.
    Should be a fully comprehensive strip down to re-build.
    And these may be able to help With Spares:-
    http://www.anylaptopspares.com/categorie...
    If these prove to be unsuccesful, or too expensive i,d suggest regular visits to e-bay, and pickup a faulty one with damaged Motherboard.
    If i can assist further.
    Please feel free to post here.
    Mike @ compurepair.
    Hey,
    No problem, glad i could help.
    I don,t think it,ll be the display drivers personally but worth a try.
    I deal more with the actually repairing laptops.
    thankyou very much for the rating.
    Don,t let the computer break the bank, some times they,re more to get fixed.
    At worst case i,d think new LCD And inverter Board.
    Go inverter first 90% cheaper.
    Regards mike @ compurepair.
    HI,
    The inverters a small board about 1" by 6" approx.
    it,s just the mater of getting into the lcd panel.
    IT will be at the bottom centre of the monitor screen.
    The Inverter is what keeps the current flowing to the cfl tube, converting the current, upto 150volts.
    Once your in te screen, its a simple remove-replace board, 1 cable usually 2 core to inverter board/tube. and a multi-core to screen.
    if you get stuck or need fuurther assistance during installation. im here for you.
    Regards mike @ Compurepair.
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Polaroid TLX-04011C 40" TV Flickering Screen
That problem with ur panel. you can do nothing about it ..
repairtv ca
Jan 15, 2014 | Televison & Video
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Dark display on hp 4600 color laserjet
This could be a faulty Formatter board. Can you swap it with a good one?
Mar 02, 2010 | HP LaserJet 4600dn Color Printer
Video graphic display changes color
There are some possible reasons on why this happens. One reason is that the video card could be faulty or the connectors arn't connected properly or the cable connected to your laptop screen isn't in properly.
Nov 04, 2009 | Gateway 200STM Notebook
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
HP Pavilion zd8000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
