Peavey KB 300 amp problems
Peavey KB 300 keyboard amp's 15" speaker stopped working. The horn speaker still works. The only fuse I found inside is still good. Any suggestions?
  • 1,512 Answers
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
regards
Graeme
Posted on Mar 08, 2008
I WANT TO SPLIT MY PEAVEY KB300 AMP FROM THE SPEAKER SECTION BUT I AM NOW GETTING A DISTORTED SIGNAL MAYE THE WIRING IS WRONG ANY CLUES
Posted on Apr 07, 2010
Where 's the fuse for my kb 100/200 watt amplifier
The fuse is INSIDE the unit and if it blows, then there are other damaged components that require going to a repair shop to repair before replacing the fuse.
Aug 14, 2011 | Peavey Electronics Peavey PR15D 15" 200...
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
Titanium high frequency drivers not working. Is there a fuse in crossover?
i) I believe you can access the fuse by removing the Input Jack Panel.
ii) If fuse is OK, then unscrew the horn unit, take off one speaker wire & measure resistance. If it is open circuit then you can order a replacement horn diaphragm (if you feel confident to fit it to the horn).
Feb 22, 2011 | Peavey PR15 400w PA Speakers
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
The horn works but not the 15" you can hear the
Hi, problem can be solved. The problem can be from two places,
From the speaker and,
also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound..
'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
Troubleshoot the above, and problem solved,...
Hope that helped..
Thanks fro using fixya.....
Oct 29, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Wiring problem on kb 300
You have probably bypassed the crossover that directs different frequencies to the appropriate speaker/horn.
The speakers are designed to be used the way they were delivered. It is easy to damage them when connected wrong.
I would suggest you restore the circuit to the way it was designed to avoid damage to speakers or the amp.
Apr 07, 2010 | Peavey Music
Opening the speaker box, Peavey KB 60 Amp
Hi...
A couple of top screws and some on the back lip of the chassis . The amp slides out but be careful not to pop the speaker leads I own a KB50 and have worked on other KB amps.
Sounds like you need a new reverb spring set.
Peavey is very good for parts
Mar 29, 2010 | Audio Players & Recorders
Horns don't work on sp2 speakers
I've got Peavey SP2's and SP4XT's and they have one common problem. The 22XT Driver needs replacing from time to time. It could be a power spike, overdriving from amp, over heating or dirt/water in horn. The driver is very easy to replace and costs about $40.00. Remove the horn, carefully lift the horn and disconnect black and red wires. Remember red is always +. Remove driver from horn with socket wrench or socket screwdriver, clean the circular gap on horn with masking tape to remove dirt, hand tighten driver screws, connect red and black wires, carefully set horn back in SP2 enclosure and slowly bring up the power. Also be sure to be very careful when setting the new driver/ coil in the horn. You don't want to damage the coils on the new driver at all!
Jun 02, 2009 | Peavey CH1 Speaker
Peavey KB 300
Yes a horn can get blown. This should be 2 pieces, the horn itself and a circular driver on the rear. The driver itself will have what is called a diaphragm that can be removed and replaced. That is the part you want. Open up the speaker and get the part number off of the back of the horn and order the diaphragm from Peavey.
Dan
Aug 27, 2008 | Audio Players & Recorders
1,505 people viewed this question
 Grubhead
Grubhead
