Question about Radio Shack Pro-97 Handheld Scanner
Raidoshack 1000 channel scanner
Hello I have a radioshack scanner tha is locked out wont scan please help me clear all ferqu
  • Anonymous Mar 14, 2014
    hello, i need a on off volumn switch for my scanner. radioshack no longer repairs or have parts. i need specs. fot the pot.
    radioshack parts no. 10983344.
    on the side of the pot there is printer "a50K" i need more info so i can locate a replacement. can you help?
    i think the manufacturer is ALPS electric.??
    their numbers are "similar" to some number i've located on radio reference pro 96 forum the switch no. (alps) rko971110 10kb 10i dont find that exact switch . any ideas??
Dear,
where writter in Radio Sahck pro 97 the frequency 154.410Mhz it go to 154.4075. Why????
how change of "steps" in 137-174mhz???
Thanks,
Rosendo
PS8RSA
ps8rsa@hotmail.com
Posted on Mar 20, 2008
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Posted on Mar 08, 2008
Blocked channels
here is the manual it should help
Jan 18, 2014 | radioshack PRO-164 Radio Scanner -
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
the channel number (1-200)
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
Need the manual for your scanner? You can download/print it here:
Nov 05, 2009 | Radio Shack Pro-82 Scanner
We have a handheld radioshack 1000 channel scanner. All channels are locked up. How do we unlock?
try holding the LO (lockout) button down for a few seconds and it will probably unlock all the channels on the bank its locked up in, then move to the next bank of channels and do it again
Dec 25, 2008 | Radio Communications
All Channels Locked Out
Link: http://support.radioshack.com/manuals/ome20-525.pdf
You must complete a reset, see owners manual above link and see page 83.
Note: Please vote for me..
Thank you!
Jan 27, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
363 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
