You can access the front thermal fuse if you remove the four screws holding the front panel on.((two in door and two opposite) Pull out on front top of panel, and pull off hooks on bottom after getting pulled out on top. sometimes door can stay on on its hooks, but need to take out four screws. There is a white one inch long fuse by blower that may have opened, another on heat cone which is less likely. Clean venting if this is the problem. Have unplugged, and watch out for sharp edges.....
good luck
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make
sure your dryer is plugged in. Also, check the circuit breaker panel to
make sure all the circuit breakers are in the correct positions. Or
check to make sure no fuses in the fuse panel are blown. Try plugging
something else into the same outlet. If it won't work either, then there
is likely something wrong with the power outlet. Any of these could be
the reason power is not getting to your dryer. Also, refrain from using
an extension cord to plug your dryer in.
Door Switch
If your dryer's door switch is defective, it will not
allow your dryer to start. Test your dryer's door switch. If it is
defective, replace it.
A dryer cannot start if its start switch is
defective. Test your dryer's start switch. If it is defective, you will
have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to
your dryer's exhaust duct (in most models) that is designed to blow if
the dryer overheats. A blown fuse would cause your dryer to not heat, or
to not work at all. Open up your dryer's cabinet and locate its thermal
fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is
preventing your dryer from starting. Open up your dryer's cabinet. Test
each of your dryer's thermostats. Replace any that have become
defective.
Your dryer's timer will not function properly if its
motor is malfunctioning. Open up your dryer's cabinet and locate its
motor. Test the component. If it is not functioning as it should,
replace either the motor itself, or the entire timer assembly.
A burned out motor could be what is keeping your
dryer from starting. Test your dryer's motor and if it is defective,
replace it. You will have to open your dryer in order to gain access to
its motor.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
