Question about Aurora Global AS501X-MS Shredder
Shedder one works
In the reverse mode, can you help
  • 2 more comments
  • Diamond69 Mar 07, 2008
    I have the Aurora shredder, model number AS501X-MS, it only works in the reverse mode.
    Please help
  • DrWilson Aug 04, 2008
    I believe the gears need to be replaced. Where can I get the parts?
  • shreddergal Oct 29, 2008
    I think I have the same problem. Shredder works fine in reverse. But paper sensor does not catch. I have to force paper down the center before the shredder will work. Is this a simple, cheap fix? How much would it cost and where do I bring it? Or should I just buy a new machine?
  • winkspop May 13, 2009
    The AS501X shredder I have just stopped working in reverse. I've had the shredder for about 5 years so it doesn't owe me anything. I took the shredder apart and found that a gear that works the reverse mode is broken. It I can find a gear I can fix the problem.
I have an Aurora AS501X-MS that would not feed and reverse works fine. My unit has a lever and cam system to start/stop the shredding. The reason it only works in reverse is becase the finger on the lever is broken off. Without the finger the shedder has no way to sense the paper, therefore, no tripping the motor switch. The default state in AUTO is Motor-OFF. For shredding (Motor-ON) the following takes place -- as long as there is material pushing the fnger verticalthe motor will run. If there is a jam, reverse trys to push the jam out and reset the lever to the Power-On position for AUTO. [note: I have since found out a CD was inserted. This model (AS501X-MS) is not rated to shred CD/DVD,;Five (5) sheats of paper max.]
Fix: repair broken finger or buy a new part. I am trying the repair option.
Posted on Jun 12, 2008
    Scholar:
  • 102 Answers
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Posted on Mar 10, 2008
2 Suggested Answers
  • 1218 Answers
SOURCE: My shedder won't spin at
Try cleaning the "eys" in the middle where you insert the paper...if that dosn't do it it is likely you have lost the PCB inside...call Royal at 1-800-524-0799 for parts assistance.
Posted on Oct 14, 2010
How to clear a jam in a shedder?
Most shredders have a reverse feature to allow jam clearing. If the jam is so sever that neither forward or reverse will work, you will need to unplug the unit and manually clear the shredder blades.
Mar 12, 2015 | Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
My shedder won't spin at all any more in the forward mode. It only goes the reverse? What can I do?
Sep 12, 2010 | Royal Office Equipment & Supplies
Shedder OM99732 in automatic mode will start and shred when paper put in, but will not shut off. It also appears there is some type of plastic covering the screws so I am unable to remove the cover. It...
It sounds like a piece of paper is blocking one of the two photo cells that detected when a piece of paper (or a CD / DVD) has been inserted for shredding. The (six) screws that secure the top are accessible from the bottom of the shredder unit after it is removed from the paper bin. Be careful: There are three different sets of wires connecting the top control plate to the bottom motor and cutter assemblies. It is not too difficult to get inside the shredder "head" if neccessary.
Aug 23, 2010 | OfficeMax Office Equipment & Supplies
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
Aug 10, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
Shedder Doesn't Work
Are you sure the saftety switch on the left side of the shredder is in contact with the small metal latch on the inside left side of the basket. The machine won't work unless the ssfety switch is pushed in.
Oct 23, 2007 | Aurora Global AS702MX Shredder
Aurora Global AS501X-MS Shredder Logo
549 people viewed this question
Top Aurora Global Office Equipment & Supplies Experts
chargerhp
chargerhp
Adorjani Laszlo
ray gallant
Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
