Question about Sony DSR-45 Mini DV VCR
Tape is not threading
When the tape is loaded. its not threading ... what should i do ??? I am having the same problem and I get an error code of C3125. I've already tried the reset button under the front panel and I've unplugged the power.
    Genius:
  • 1,139 Answers
Hello optasia,
Check to see if the gear or wheel is engaging the capstan.
This more then likely is your problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 17, 2008
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
Mar 22, 2010 | Sony DSR-1500 Mini DV VCR
Sony evo 9850 error code 20
From what i've read an Error-20 on a Sony BSP deck is a tape transport problem. Someone with the same error code (on a BSP model) said the actual tape loading mechanism was bad and they had to replace the hardware inside the machine that loads and ejects the cassette.
Jan 23, 2008 | Televison & Video
Sony UVW 1800 error code 02-403 - tape is out, code won't go away
Error 02-403 is "tape slack in ff/rew". Although you were able to get the tape out, the threading ring may not have returned to the unthread position. With the power disconnected and the top of the deck off, look at the mechanism; on the right side, there is a small gray motor with a black wheel in front of it. By turning this wheel, you will be able to make the threading ring turn; turn it so the ring goes clockwise. When the ring has gone as far as it can, it will be in its unthread position, and the deck will probably work normally.
Dec 17, 2009 | Sony UVW1800 VCR
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
My Panasonic NV-SD270 video player wont play or release a video cassette and shows the error message "F05". Does anyone know what this means? thanks Chris
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Apr 29, 2008 | Televison & Video
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony DSR-45 Mini DV VCR Logo
262 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
