Question about Pioneer VSX-D514 Receiver
Receiver problem hooked up an input live on my pioneer vsx-D514 the unit auto turned off and wont turn back on. have checked fuses all ok. Help me obiwan.
  • 1 more comment
  • Sly 1 Apr 03, 2008
    Would not turn back on after brief power interruption. Fuses are all good.
  • Anonymous Jul 06, 2008
    similar... died after a power outage and won't power up now.. ..no idea why? anyone?
  • Anonymous Apr 19, 2009
    i spilled tea on my sterero and for months i thought it was broken...i had checked everything including taking it completely apart. i finally came upon this thread and after pressing enter and advance surround sound for secs boom it turned on....thanks so much and i hope this helps
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Posted on Dec 31, 2008
  • 4 more comments
  • dandydon60 Aug 26, 2011
    8/26/11//////////this is the fix for sure.....works in Florida and it should work for you..............
  • rhedzirus
    rhedzirus Jul 10, 2012
    I was stunned. This solution worked for our unit that looked like it was beyond dead. Thank you!
  • rhedzirus
  • tedd_e
    tedd_e Jul 10, 2012
    Same, totally worked for me and I thought this thing was a gone'r for sure! You are some sort of wizard sir!
  • tedd_e
    tedd_e Jul 10, 2012
  • carringbush5
    carringbush5 Sep 26, 2012
    I can hear the ticking noise to start up but unit is still not coming back on
    New Friend:
My VSX-522 did reset by holding down the power and surround sound buttons for 2 seconds. I heard the relay click and the display lit up. Great tip. thank you!
Posted on Sep 06, 2015
I pressed the Advance surround button and enter button and it turned on. Thanks my friend God bless you. I was just wondring why the unit does this becuase I had my unit for over 4 years and this is the first time it had this fault that it did not want to switch on.
Posted on Jun 04, 2011
Thank you is working for me, this was very good idea, thanks again
Posted on May 16, 2011
    Problem Solver:
  • 6 Answers
Sounds like the main board is fried. Did you use a surge protector?
Posted on Aug 05, 2008
I was listening to music,then after 30 mins my pioneer vsx d514 shutdown, completely lost power and now does not turn on, any ideas on what has happened
If the unit has no power whatsoever then it's likely an internal fuse in the power supply section has blown. It could have gone for a verity of reasons, replacement might cure the problem, but if it blows again or straight away then there is a more serious problem.
Dec 16, 2016 | Pioneer Audio Players & Recorders
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
My wife moved the tv around but now we only have a black and white picture on the tv dvd is ok
Check the Red, Green, and Blue cable on the back of the TV. It's either Red or Blue that's loose. Hope this helps.
Jun 13, 2010 | Pioneer VSX-D514 Receiver
My receiver shut off after use & will not power on
Pop the top and check the fuse by the AC plug on the inside. Chances are you will need a meter to do this since most receiver fuses are either white or gray. If you have a multimeter, dial it to ohms and you will see a sign that looks like -))) When you touch the two leads together you should hear a tone and if digital, the display will read "1." Take the leads and touch either side of the fuse, if you hear tone, fuse is good. No tone, bad fuse. Radio Shack carries fuses of all types and usually has them in stock, and can test yours for you as well. If the fuse is O.K. then your unit needs to be serviced. It's either a power supply, transformer, or chipset. Hope this helps
Jul 01, 2009 | Pioneer VSX-D514 Receiver
Pioneer VSX-D903S
just try prologic mode no tv uses 3 ch nomore ok and turn on ch a speakers only
Jan 29, 2008 | Pioneer VSX-D908S Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Pioneer VSX-D514 Receiver Logo
688 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
