PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Dell webpc,,2 short beeps and keyboard err...
By Ray1955 on Mar 07, 2008
I have an older dell webpc,,trying to put os on it,,but when it boots up,,I have 2 short beeps and it says keyboard error,,,I have tried other keyboards but to no avail,,any suggestions,,,
thanks,
Ray
Comments:
Mar 08, 2008
- I have tried to get into bios but the keyboard does not work,,I have tried several keyboards and still the same,,It has three usb ports one for keyboard,one for mouse and an extra,,i've tried all three with the keyboard to no avail,,memory is good and have even switched that,,When it boots up it does say usb ports enabled,,,Yep just two short beeps flashes the setup screen and then goesblack with a blinking cursor in left hand corner,,have to shut it down then cuz nothing else happens,,I have even tried booting from the OS disk I wanted to put on it,,no luck,,
Mar 08, 2008
- I have checked further about this issue and I was told that the 2 beeps mean that the parity cannot be reset,,,,any suggestions on how to do this without a keyboard,,
Ray
Solution #1
posted on Mar 07, 2008
Somewhat Helpful)
Destinova
Rank: Wiz
Rating: 78%, 57 votes
Does the keyboard still work? more often then not there is either something in the socket OR it is a bad socket.. Now depending on the machine you could try reseeting the configuration data in the bios.. I have seen this work with limited success Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
Compurepair
Rank: Wiz
Rating: 84%, 786 votes
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Comments:
Mar 08, 2008
- Perhaps if you,d read my Post Here.
You,d have seen that 2 hours Ago.
You don,t reset Parity, it means you have the wrong or faulty RAM.
MEMORY.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
what is the price for microsoft notebook receiver v2.0
Answer
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send Machinery until you... (More)
Answer
I have Powerspec tv , after turning on the TV ,no pictures after a second?
Answer
When turn on TV on after few seconds the display is blank?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Desktops:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
