Logitech Cordless Rumblepad 2 Vibration Feedback Gamepad (GAMELOCRMBPD2) Logo
Posted on Mar 07, 2008
Gamepad use just bought a rumblepad and its installed ok but not many games support pads . is there software support i can get, i.e emulation ?
A
Anonymous
The program that comes with the rumblepad allows you to map actual keyboard functions to each button.
Rumblepad 2 Game Pad: my logitech gamepad is brand new, as is my compute...
http://www.logitech.com/en-us/441/292?selectedcrid=441&selectedcid=292&WT.z_sp=Product&osid=&bit=
How do i use the logic 3 gamepad with cod4 pc?
i had lost my installation CD of atek game pad so please give me that software
2helpful
2answers
LOGITECH RUMBLEPAD2 ON VISTA PC
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
Cheers.
1helpful
I recently downloaded "Fallout 3" using "Steam" and bought the Saitek "P380 DUAL ANALOG" gamepad to play it with. A message appeared on my screen saying that the gamepad was installed and ready to use but...
XBOX360 Controller Emulator
http://www.tocaedit.com/IB/index.php?automodule=downloads&showfile=4
It helps. I got my saitek ps2700 to work with fallout3 with it. Yust download and install using instructions in readme.txt.
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
1helpful
Gamepad wont work
game pad is need to install in to yr pc 1 u have to install drivner then u plug yr gamepad to usb pord
thnaks
jo_chinmay
Emulator Project64 plays Nintendo 64 Games
sory don't have a solution i have the same prob i have a logitach wingman extreme gamepad controller and it says it is working fine but dosent work with pj64 games like perfect dark or golden eye but i can play them with my keyboard wtf ?
2answers
Rumblepad 2 can't move
Do you still have the receipt?
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
THEN UR RUMBLEPAD 2 OR 1 SHOULD WORK 100% PERFECLTY + BIT MORE EFFECTS AS YOU HAVE DX10.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO --- [email protected]
Logitec rumblepad 2 not working with nintendo emmulators
You have to program the individual buttons in each emulator. Switch to gamepad mode if applicable.
Top Logitech Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
