Question about Ulead Videostudio 8 for PC
Audio in EasyCap/VS10
My VS10 is seeing the video from VHS tape player, but not audio. How to check the source of the problem? The recording is with audio - checked on TV set. Setting the "Preview audio with USB device" doesn't work. I tested EasyCap & VideoStudio 10 on Vista and Win2000+ServicePack 4. Can anybody help me?
Greg
poczta@gbkonto.net
  • 8 more comments
  • Anonymous May 02, 2008
    I am having the same problem. Video is fine but no audio. Also enabling Audio via USB doesn't work.
  • Anonymous May 27, 2008
    also able to capture video but audio is distorted please help
  • jimmy40 May 28, 2008
    I so have the same problem,no audio. was told to put audio line into the soundcard in line, Who knows it may work, going to try.
    "Other Thoughts: Keep in mind that if you use the audio inputs it will not output that sound directly to your speakers like it might do if you use your soundcards. That's fine for capturing but if you intend to use it to be able to watch stuff on your computer screen then line in on the soundcard is they way to go"
  • rm1608 Jul 01, 2008
    Sometimes I need to capture only sound of my old vinyl records by Easycap, but I don't know how to do it.
    If anyone can help me, I thank you a lot.
    Little World, from Brazil
    rm1608@yahoo.com
  • Anonymous Sep 02, 2008
    audio in easycap capture sounds like its crashing and dark vader in star wars
  • welshviking Oct 11, 2008
    i can get the video feed. sometimes i have to change the crossover settings to reinitialize the device. if i choose the s-video input then i can get the sound but then the video feed is green in ulvead vstudio
    btw, running stk1150 driver and ulead vstudio 10
  • jazzycats Jan 23, 2009
    I have the same problem,..all of a sudden no sound and only black and white images from dv camera.. I tried the kworld driver update,..but it wont take,..do you know where i can find the one mentioned abouve? the usb emp audio driver download? Any help would be great!
  • Anonymous May 08, 2009
    It is lame.
  • UJJAINKUMAR MHASAVEKAR May 11, 2010
    which capturing card are u using?
  • smbrandt64
    smbrandt64 Nov 20, 2012
    I have ss very simillar problem where the video records fine, but the audio will not record. I have downloaded various quick fix methods and tried just about everything I can think of. can you help me please?thanksSMB
Hi
i upgraded the driver to stk1160 and the device is working correctly. i still cannot get the sound in the pc loudspeakers coz there is no usb-audio device installed for playback, just for recording. but that is a minor glitch. the sound is recorded with the video capture.
i have not tested the audio capture yet but i assume it will work just the same.
btw, i uninstalled ulead videostudio and just use windows moviemaker, the quality is fine.
download the driver from http://rapidshare.com/files/130191719/syntekSTK1160.rar.html
Posted on Nov 12, 2008
  • 3 Answers
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly.
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Posted on Jun 05, 2008
I finally found a way to listen while playing
I had problem of only hearing after I record, just go to control panel, and look for the recording tab, then properties on your sound input, then search for "play it through",, and choose your speakers, sorry for not giving exact details due to difference in our OS's
hope this helps
Posted on Jun 28, 2010
My EasyCap is seeing the video from VHS tape player, but not audio. How to check the source of the problem? The recording is with audio
Guyz, if you still have problems with sound (noise) using Empia based EasyCap, download these drivers from here:
http://www.zshare.net/download/51444086407e957b/
Posted on Apr 28, 2009
Also same problem no audio although vhs transferring great, WHY???help
Posted on May 28, 2008
    found this answer on another site, maybe it will work
    Other Thoughts: "Keep in mind that if you use the audio inputs it will not output that sound directly to your speakers like it might do if you use your soundcards. That's fine for capturing but if you intend to use it to be able to watch stuff on your computer screen then line in on the soundcard is they way to go"
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
Crackly sound when recording vhs tape to disc
try new cables going from the vcr to the video capture (yellow red white)
Dec 01, 2009 | Pinnacle Dazzle DVC-100 DVD Recorder
U lead video capture
It's either something to do with your PC sound settings. Maybe the recording level for sound is set to low or switched off. Or it's in the Easycap software where the audio is switched off.
Jun 11, 2017 | Ulead DVD Workshop 2 for PC
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Sep 30, 2007 | Ulead Videostudio 8 for PC
Problem in Capture
I don;t know if this is the solution to your problem but it might work, as it did for me.
When you start ULead Studio click on the capture tab, then click on the camera icon named "capture video", then in the middle of the page you will notice the "options" icon (looks like a cog) go to Input source and then at the top of the window you will see "input source" again, click the dropdown list and select "video composite". Try that and see what happens.
Aug 01, 2007 | Ulead Videostudio 8 for PC
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Ulead Videostudio 8 for PC Logo
16,058 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
