Question about Radio Communications
KENWOOD R2000 POLICE SCANNER
I CANNOT GET THE CHANNELS TO GO ANY HIGHER THAN 29.999.0 AND ALL THE CHANNELS I NEED TO SCAN ARE 150.425.0 AND HIGHER AND I CANNOT FIND A MANUAL ONLINE ANYWHERE. I WOULD ASSUME BECAUSE THE SCANNER IS A 1994 MODEL. CAN U HELP?
  • 2,130 Answers
The R2000 is a shortwave receiver, not a Police scanner, covering 100 KHz to 29.999 MHz.
There was a converter available (VC10) that connects to the back of the unit that will allow tuning between 118 MHz to 174 MHz.
http://www.rffun.com/catalog/commrxvr/r2000.html
Please let me know if I can be of futher assistance to you.
- Jim
Posted on Mar 08, 2008
What did you mean by change the squelch?
The squelch control gets rid of the hissing on a blank channel. Finda blank channel, turn up the squelch control until the hissing stops. The scanner should then scan the channels and stop on a busy one.
Jul 12, 2014 | Uniden Bearcat Scanner Bc355c 800 Mhz...
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
I can't get my uniden bcd396xt police scanner to talk. it will scan, but not talk
Hi Sue,
No it's not a Police scanner, rather a radio scanner.
I will scan, but not receive transmissions.
Two reasons for this:
1. Do you have any frequencies programmed in the scanner, if not, there's your first reason answered.
2. Do you have frequencies programmed but the channels are locked out? If so, there's reason 2 answered.
To unlock channels, you need to press Mon/Hold key to stop the unit from scanning. Now press mon/Hold key and as you do so, notice if you have frequencies programmed and not just a bunch of zeros showing on your display. If zeros are displayed, example: 000.0000MHz, then you need to program the scanner with your favorite frequencies, and I advise that Police should not be programmed. If you do have frequencies programmed, then using the Mon/Hold keys as stated above, go through each channel and unlock each channel using the L/O key, until the L/O icon on the display goes out.
I Hope I have assisted you with your query.
Cheers,
Peter
Mar 11, 2013 | Radio Communications
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
Can not get our police channels to scan, the fire and ambulance work
If your scanner previously picked up your local police communications, it's possible that their system has been upgraded to a new trunked radio system - a system that your BC370CRS is not capable of monitoring. For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Jan 10, 2010 | Uniden BC370CRS Base Scanner
Citizen band scanner'
Thanks I solve the problem by going online to the local police dept. in my area and located the channels I needed' then program the scanner.
Aug 08, 2009 | Uniden Radio Communications
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
Dec 09, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Communications Logo
2,164 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
