Question about Palm Treo 755p Smartphone
Bluetooth code when i try to handsfree sync my phone to another phone the other phone ask for keycode or some code of the sort where do i get that code from?
  • 405 Answers
The code is 0000
That's right it's that simple four zero's
Hope this helps
http://pchelpforanyone.blogspot.com
Posted on Mar 07, 2008
Can I fix my phone to a supertooth hands free kit
1. From OFF, press and hold the On/Off (8) button for 10 seconds until the Bluetooth Indicator (4) turns blinking red/blue.
The handsfree kitis now in pairing mode.
2. While the handsfree kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function and execute a
Bluetooth search. (See your phone's manual.)
3. When the phone displays the list of Bluetooth devices, select ST
BUDDY.
4. If the phone asks for the password/pin code, enter 0000 and pressOk.
5. The handsfree kit is now ready to use.
Jan 04, 2018 | Radio Communications
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
I have a bluetooth plug-in handsfree car kit model#bthf0082 it asks for 4 digit pin on mobile when i try to connect device?
HI, TRY CODE 8888 ON YOUR MOBILE PHONE TO CONNECT THIS BLUETOOTH DEVICE BTHF0082. HABIB
Mar 09, 2011 | Cell Phones
How to activate k750i bluetooth hand free
Activate blutooth from the main meny/setup (tool symbol), then navigate to the far left meny tab (communication) and turn ON your bluetooth radio, and enable the "visible" status for your phone. Then turn on your handsfree device, and the phone should either find your hands free or vice versa. Many handsfree devices will ask you to enter a pin code once it has connected to the phone to allow connection, so be sure to have the code ready.
Oct 20, 2010 | Sony Ericsson K750i Cellular Phone
Just got a new iphone. Will it sync with my 2006 mdx handsfree system? It's been a long time since I hooked up my last phone. Where do I start?
It should work off of the bluetooth on your phone, if you turn bluetooth on the sync should pick it up
Apr 11, 2010 | 2006 Acura MDX
How to sync my bluetooth?
Hold the power button down approx.
6 seconds until the blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Go to your cell phone after you've done the above directions and:
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H500.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
I hope this helps anyone else who's having a problem pairing their Motorola H500 Bluetooth headset :)!!! I just got mine to work w/ the same info!!!
-Rebecca :)
Dec 29, 2009 | Motorola Mobility H500 Wireless Headset
Sync Lexus GS300 Phone Book with iPhone 3G
You can't as iPhone support only handsfree profile via bluetooth.
Jun 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
HandsFRee Problem
I have MANY of these radios BRAND NEW with codes for sale if anyone has to replace a bad unit. $270 8b748a8.jpg
Sep 10, 2008 | 2004 Acura TL
Bluetooth , handsfree
when you select your connectivity you should see sync and BT there
Jun 01, 2008 | Motorola Mobility RAZR V3
Palm Treo 755p Smartphone Logo
19 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
