Question about Compaq Presario R3000 Notebook
Presario R3000 quit recognizing the DVD/Writer
The laptap is about 4 years old. Just out of the blue, it no longer sees the DVD drive. It doesn't recognize it in setup either. The HP site has a link to this problem, but is unavailable.
  • natewilson Mar 07, 2008
    Re-installed drive. Solved problem.
  • Tygh Duval
    Tygh Duval May 11, 2010
    I think the fact the drive is not recognized in setup (aka the BIOS) is the key. Whether Windows is even installed or not, the drive should be recognized in the BIOS.
    1. Does the drive eject when you press the eject button?
    2. Is the drive easily removable or is it screwed in?
    Sergeant:
  • 300 Answers
Sometimes you luck out and it's an easy fix!
Posted on Mar 10, 2008
I removed the drive and reinstalled it and solved the problem. Thank you for your fast response. Obviously HP doesn't out us little people.
Posted on Mar 07, 2008
I have a Compaq Presario R3000 laptop. Is it capable of burning DVD's and if so, do I need additional software. I have made a video with sound on Kizoa and I cannot burn it to a DVD as the program...
According to epinions Your Notebook is NOT capable of burning DVD's. It can only burn CD's.
http://www.epinions.com/specs/pr-Compaq_Presario_R3000_Refurbished_dz338ur_aba_PC_Notebook
Jul 11, 2011 | Compaq Presario R3000 Notebook
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
Burning DVD
Impossible, since your device _reads_ CDs/DVDs, but does not _write_ either CD nor DVD.
Do you have a USB memory-stick (holding 4Gbytes) ?
If so, copy the files to the memory-stick,
and take the memory-stick to your friend's computer,
presuming that his/her computer has a DVD-writer.
That DVD can be _read_ on your computer.
May 22, 2009 | Compaq Presario R3000 Notebook
Compaq presario f700 sudden shutdown
Less than one year old? Then, it can be fixed at NO COST to you, via "warranty" from the vendor.
Apr 12, 2009 | Compaq Presario-Notebook 700 Series, 2500...
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
My presario R3000's combo drive no longer wants to burn dvds
Try a different Brand Of DVD Maxell Typically Work Universally With Failing Drives or older Drives or touchy drives...
Nov 17, 2008 | Compaq Presario R3000 Notebook
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Presario 3700 dvd writer no longer recognizes bland dvd disc
the lazer lens of your DVD rom was not able to read the disc. Clean the optical lens with soft materials. if same errors after cleaning, Be sure that your system is stable can can cause error on DVD rom if either that is not the case. maybe its time replace your DVD rom.
Jan 10, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario R3000 Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
