Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
Pathfinder watch ??
I dont know if this site deals with Casio watches as well but if it does this is my problem:Ive got a Pathfinder watch that I have had for several years and never had an issue but all of a sudden now the barometer and the altimeter are not functioning ,when I press those buttons I get an error message on the watch.Comp.works fine its only the other 2.Any info on how to reset or whatever would be great.
  • Anonymous Aug 10, 2008
    Casio Triple Sensor Pathfinder PRG-40T-7VDR
  • 374 Answers
That old of a watch would need to be sent in. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
Set casio pathfinder watch
try this site:
http://www.ehow.com/how_5214673_operate-casio-pathfinder-watch.html
Nov 12, 2014 | Casio Pathfinder PAG80-1V Watch
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Hi....I`need the Manual operations of Casio Pathfinder Watch Silver PAG70T
    You can get instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals",
    watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Jul 02, 2010 | Casio Pathfinder Watch Silver PAG70T 7V
    I just purchased a casio pathfinder watch without a instruction manual model PAW1500T-7V how do I find one
    If you haven't got instructions on how to do this, you can get
    watches;
    Accept terms
    Jun 15, 2010 | Casio PAW1500T-7V Atomic Solar Pathfinder...
    Where is the ac contact button?
    Select "support" and the "manuals", watches;
    Accept terms
    Mar 16, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Hello i recently purchased a casio pathfinder but have mislaid the instruction leaflet it seems to work differently from other watches which i can set easily is it possible to have a leaflet downloaded its...
    Hold down the adjust button (top right) and flick through with mode (bottom left) when you are done hit adjust again and it will take you to the next 'page' of settings. Same deal there. Use the top and bottom left buttons to change number up or down
    Good luck
    Dec 01, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio Pathfinder 2273 Reassembly Help
    Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
    Nov 18, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
    398 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
