Question about Kitchen Ranges
HI, I'VE JUST BOUGHT A DCS FREE STANDING RANGE, BUT THIS UNIT IS FOR NATURAL GAS CAN I USE PROAPNE IN THIS UNIT
  • hardell Jul 28, 2008
    My range was converted to propane but they did not do the burners. the btu way to high . looking for conversion kit for it
I have the same problem since last year. We purchased the range over the phone from Puerto Rican branch of Sears. They REFUSED to give us the conversion kit. In New York, they told us that they do not have it...I do not know from where to get those orifices...any advice?
Posted on Jun 07, 2008
  • 640 Answers
No,you have to convert it to propane.The regulator,orfices need to be changed.Call sears or where you purchased the oven and ask them for a conversion kit.Its also not difficult to do.
Posted on Mar 08, 2008
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Can a DCS 60-10-2 be converted to L.P.?
Hello. Yes it can be converted to LP, the kit part however, not sure. I would suggest contacting the manufacture to see if one is available, and who/where to get it. Here is some info:http://www.dcsappliances.com/customercare/contact-us.cfm
or you could contact a local servicer by checking your phone book, under "restaurant equipment repair".
Hope that helps, and thank you.
Feb 21, 2009 | DCS 60-10-2 Gas Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
This should be fairly easy to do. You will have to get new jets that are sized for propane. These should be readily available. The jets on the stove top are located under each burner in the top of the pipe that delivers the gas. Remove the burner and you should be looking at a small hole in the center of a brass fitting, that's the jet. It unscrews and the new jet screws in. You may also have to adjust the simmer. This adjustment is located on each burner valve. When you pull of the knob, the adjustment will most likely be in a hole on the shaft where the knob came out or as was the case with my stove, it was behind and beside the shaft, just visible with a flashlight. This adjustment is done with the flame on in low medium. You may need to hold the shaft with pliers to keep the valve from opening. Turn the screw a half turn or so until the flame simmers to your liking and is not so thready tat it wants to go out.
For the oven, this will either be an adjustable jet, or you will need to replace it with one set up for propane. Either way its a doable project.
Mar 07, 2008 | Kitchen Ranges
Frigidaire convection free standing range
new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Nov 24, 2007 | Tappan MGF500PBW Gas Kitchen Range
Oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Jul 30, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
240 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
