Haier XQBM22-C washer stopped spinning
My Haier XQBM22-C washer stopped spinning. Help. It was just working yesterday. It adgitates in the wash cycle, but won't spin in the spin cycle. I called the guys @ Haier, finally after over an hour of trying to get an answer from someone, a tech told me that it may be the belt. I don't know what to do, does anyone have any suggestions?
thx!
  • candyc186 Mar 09, 2008
    I have the exact same problem!
  • rodney226 Mar 11, 2008
    What did you end up doing to fix the problem?
Do you hear the motor hum, as if it wants to spin? Mine always sounded like it was spinning from the other room. Until one day I found that a load of wash was still drenched after going through all the cycles. I ran the machine through the spin cycle again, but this time I peeked under the lid and saw that the tub was not spinning, though I could hear the motor was engaged. Being careful to not trip the lid switch, stopping the cycle, I found that if I could nudge the tub a bit with my finger I could start the tub to spinning. This process was a drag, because I would have to stay with the washer until it was fully into the spin cycle.
Fortunately I had another machine of the same make and model in storage. I cannibalized the older machine for it's belt. I then installed the belt into the newer machine, and now it runs as it should. The whole process took me less than fifteen minutes, and I can barely tie my shoes.
I would say that if your machine's symptoms are the same as what I had described about mine, a new belt is in your future.
Posted on Mar 19, 2008
It still doesn't work! I don't know how to fix it.
Posted on Mar 11, 2008
Haier washer model xqbm22-c, fills with water and won't wash or spin, just hums through cycle and will drain. What are possible problems?
bad water pressure switch, bad door switch? bad motor coupler and or belt. the water pressure switch does not control the spin though? so I suspect door switch or coupler
Mar 07, 2015 | Haier Washing Machines
Always unbalanced in the spin cycles
the machine may need to be releveled, if it is not level the clothes will have a tendancy to go to the low side and thereby causing the unbalanced condition
Mar 20, 2011 | Haier XQBM22-C Top Load Washer
Does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Haier XQBM22-C Top Load Washer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Does not spin
You need a new motor for it.
Jun 28, 2009 | Haier XQBM22-C Top Load Washer
My machine will just stop after the adgitate cycle.
Manually turn the knob to the spin cycle and turn it on.
If it does not spin, replace the lid switch.
If it does spin, replace the timer.
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Need a manual or the basics on how much detergent and what to do to use my Haier XQBM22 C washer
I have a problem with my Washer dryer Combo on the front it seems like the machine froze and just says CE if you can help me with this problem It will much appreciated.
Jul 29, 2008 | Haier Washing Machines
Washing Machines Logo
299 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
