Question about Sony Cyber-Shot DSC-S40 Digital Camera
Bad picture When you turn the camera on the picture in the window looks like an old tv with rabbit ears...its fuzzy and has colored lines running across the screen...
  • Hazlin Mar 17, 2008
    My camera's display is distorted and is not clear even when taking photo's
  • CameraR
    CameraR May 11, 2010
    Try this first, rap the Cybershot logo on your camera with your knuckles. If that didn't help, pinch the camera to apply some pressure to the lower right corner of your LCD screen. If either of these seem to help, then the problem is likely a loose connection on the LCD cable (an inherent design flaw of the S40). Reply back here for more directions if this helped as the above is only a temporary fix.
Well if the LCD is screw ! My was black and it got fixed with the solution. It starts with a fizzing vision then it looks screw up. It is the same problem . l fix it with the solution. Thanks I wish i found this site a couple of months ago.
Posted on Mar 09, 2008
  • Sony Master
  • 4,738 Answers
Better yet, go to Sony's website and describe the problem your experiencing. Have heard that they have sometimes offered to repair it for free as the problem is so widespread (Note that it's not on any recall list though):
http://esupport.sony.com/US/perl/emailform-di.pl?template=EN
Posted on Mar 08, 2008
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
We want to hook our small Magnavox tv to a rabbit ear antennae to get only local stations. How to do this?
Unless this a new TV with ATSC (digital) tuning built in, you will need a digital adapter for off-the-air reception. Older TV sets have analog tuners, and analog broadcasting ended in June 2009. Wal-Mart and Radio Shack carry the adapters, as do other retailers. Your antenna connects to the adapter, and the adapter sends the converted signal to the TV on channel 3 or 4.
With digital broadcasting, a strong signal is necessary. Unlike the analog days, when a weak signal just meant a fuzzy picture, a weak digital signal will cause pixellation (blockiness) or freezing of the picture, or may not even be detected by the tuner. Depending on how far you are from the station's transmitter, you may find that rabbit-ears may not work too well. You may need an amplified antenna or even one outside to get best performance.
Aug 07, 2011 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
I'm looking for rabbit ears/antenna for my Durabrand T.V.
Radio Shack, Wal-Mart, etc. all carry a selection of antennas that will work with your converter box. Depending on the strength of DTV signals in your area, you may need an amplified antenna (has a built-in booster) to get good reception. Analog broadcasts were watchable with a weak signal (the picture would just be fuzzy), but the digital system needs a good strong signal. The sales people may be able to suggest an antenna based on what other customers have purchased and their reports of how well they do. Outdoor antennas are also available if needed.
Jan 12, 2009 | Durabrand BH1304D 13" TV
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
Oct 25, 2008 | Sansui Televison & Video
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
