Question about Funai PY90DG DVD Recorder
Dvd recording problems
My Funai Dvd recorder as given me quite a few problems of late.
I get Recording Error can not record on this disc E4 54037380
I don't know why but the discs worked in the machine when I first got them but are now refusing to work. I have even tried to reformat them but they wont reformat. I use the recorder to record from cctv so the discs are used regularly but I have bought some new ones to see if overuse was the problem. It is not.
  • Anonymous Mar 27, 2008
    I have the same problem but it only applies to RW discs, I can still record on R discs, which is really strange. Can anyone suggest a solution.
SOURCE: dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
Posted on Jun 28, 2008
SOURCE: Funai DRV-B2737 Error message
Try using old-fashioned 2x DVD-RW discs, eg the cheap ones from Datawrite.
This seems to work in my machine MOST of the time.
Posted on Sep 12, 2008
ginko
  • 19396 Answers
SOURCE: funai dvd/vcr combo B2735
Try cleaning lens first.
Posted on Oct 11, 2008
var-pun
  • 331 Answers
i think there must be a daulty with the ...disk
because that has a bigger probability........
  • 9 Answers
SOURCE: funai drvr-b778 dvd record problems
try mr dvd-r discs from poundland they seem to work
Posted on Feb 07, 2010
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Funai DR-B2737 DVD recorder wont record
use mr dvd discs-dvdr youcan buy at poundland they are the only discs that seem to work
Mar 25, 2009 | Sony Ericsson w580i Cellular Phone
Dvd recorder funai
May 09, 2008 | Funai PY90DG DVD Recorder
Py90vg recording error
look for what format the dvd records on [ dvd-r, dvd-rw, dvd+r, dvd+rw. the manual showed tell you
wg
Feb 04, 2008 | Funai PY90VG DVD Player/VCR
Funai drvr-b778 dvd record problems
Jan 11, 2008 | Funai FDRV90E DVD Recorder/VCR
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Funai PY90DG DVD Recorder Logo
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
