Question about Toshiba Satellite A55-S1063 Notebook
A55 1064 dead
My toshiba wont pull any program up, it wont system reswtore or anything. it says the program needs terminated or debued, it wont do either thing.
  • 1,006 Answers
Log in with safe more ( F8 I THINK ) then go with admin privileges!Go start run type msconfig then to startup AND DESALBE ALL COMPONENTS FROM STARTUP!
Let me know if u got help!
Posted on Mar 08, 2008
Can I program the car to recognixe the key fob.
1996 Roadmaster
  1. Locate the programming connector located in the LH trunk. Trim may have to be pulled back to access programming connector. ( Connector has black/white wires leading up to it and it is not connected to anything.)
  2. Jump programming connector terminals. Leave terminals jumped unitl step 6.
  3. System should now lock and unlock doors to indicate programming mode has been entered.
  4. Press any button on keyless remote once. System should now lock and unlock doors, indicating successful programming of keyless remote.
  5. Repeat step 4 for additional remote or other existing keyless remote. NOTE: A maximum of only two Keyless Remotes can be programmed.
  6. Remove programming connector jumper wire to exit programming mode.
  7. Test remote(s).
Oct 19, 2015 | 1996 Buick Roadmaster
Ah59 02291a remote wont connect to anything?
If your remote is a Samsung, it should be able to connect to your Samsung HT-C450. Although you say it has batteries in it, those batteries may be no good and fresh ones are needed. You need to determine whether your remote can be programmed to control your Toshiba TV. Instructions for using your remote could be useful for solving this problem.
May 12, 2014 | Samsung Audio Players & Recorders
I have a rear projection 57" toshiba model 57HX93 that does not turn on I don't get lights or anything..What does it need?
Looks like this is reported a lot by people in various forums. Was the TV unplugged for a period of time? If so leave it plugged in for a day or two and try it again. Sounds like the whole line has a faulty power supply. http://www.avsforum.com/t/1146507/57hx93-dead-wont-power-on
Apr 07, 2013 | Toshiba 57HX93 57" Rear Projection HDTV
Replaced battery terminal now 2008 beetle cranks but wont start
try a scan tool reset as removing the terminal or loose terminal may have corrupted the program in the ecm for the immobilizer
Nov 14, 2017 | 2008 Volkswagen Beetle
How do I reswtore the factory settings to a acer travelmate 2400 laptop without a disk?
try to search your drives if it has a recovery manager. if you have you can re store it in its factory settings.
Mar 22, 2011 | Computers & Internet
2006 Ford Mustang GT wont start. Passenger side lights always stay on. Keyless remote wont open doors, trunk or sound the alarm (I checked the keyless remote battery it still has juice) When I turn the...
From the clicking sound and the fact that alot of your cars systems are down i would say that your battery is dead, if not bad altogether, or a terminal is loose on the battery. Check the terminals on your battery (be careful with the + (red) side and do not touch anything else metal on the car or the - (black) pole while touching it or just disconnect the - (black) for safetys sake). Check the terminals for looseness or corrosion and repair as neccisary. Then try a jumpstart but do not let the car "click" too much or you will burn out your starter. If your car's battery is indeed dead/bad you will find out within the next few times you try to turn on your car (it simply wont turn on) take the battery to a auto parts store and ask them to do a test. If the battery is ok then you can have it recharged if its bad then you will need a new one.
Dec 20, 2010 | 2006 Ford Mustang
NEED TO REEPROGRAMING A REMOTE CONTROL FOR A MALIBU 1998 HOW '?
1. Make sure ignition is in the OFF position.
2. Locate the Programming Connector in the trunk (center of rear shelf). It is a plastic connector with
two wires leading up to it. The connector is not plugged into anything. You may have to pull back
trim to access the connector.
3. The programming connector should have two terminals. Connect both terminals with a suitable
jumper wire. The Keyless Entry Module will lock then unlock all the door lock motors once. Make
sure the terminals remain connected throughout the programming procedure.
4. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for at least 15
seconds or until the vehicle automatically locks and unlocks the door locks. Your new remote has
been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each transmitter to be programmed. Do not remove jumper wire in
between programming of transmitters.
6. Remove the jumper wire from the Keyless Programming Connector.
Dec 15, 2009 | 1998 Chevrolet Malibu
I have a 91 cherokee.had less than a year.just bought a new battery 2 months ago.my problem is if i let it sit for more than 3 days the battery goes dead.could the alarm sys have anything to do with this?
Yes, and no... at this point you haven't done any testing so anything electrical is suspect. First, you need to check obvious items such as glovebox light etc to make sure they aren't staying on...Then you need to remove one battery terminal and put an ammeter between the terminal and wire. Start pulling fuses one by one till draw shown on ammeter drops. Check to see what system that fuse serves and you can begin narrowing down the problem. If after removing all fuses the draw remains it's likely that there is an internal bleed off in the alternator. sometimes a bad diode or regulator can do that. I would first have the charging system and the new battery checked ...there are defective batteries, not often as there once were, but it can happen.
Jul 30, 2009 | 1991 Jeep Cherokee Limited
Help
my cisnet [nascar] laptop wont opent to main icon screen it just stays blank with background showing
Jun 12, 2008 | ZT Group Cisnet T2060 Notebook Computer
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A55-S1063 Notebook Logo
177 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
